TextOverride从字面翻译是---不顾; 使...无效; 藐视; 拒绝制服; 凌驾; 压倒; 推翻(决议) 找了半天,在二次开发教程找到了其意义是指定标注的文字字符串。 在金山词霸中才找到有--取而代之--之意,瞎忙了半天。 以下程序将dimension的Ridial尺寸的所有属性基本列出。 Sub ReturnAcDbRadialDiamension() '文本类 Dim DefineAcadMText As AcadMText 'AcDbMText '尺寸类 Dim DefineAcadDimRotated As AcadDimRotated ' AcDbRotatedDimension Dim DefineAcadDimRadial As AcadDimRadial 'AcDbRadialDimension Dim DefineAcadDimDiametric As AcadDimDiametric 'AcDbDiametricDimension Dim DefineAcadDimAligned As AcadDimAligned 'AcDbAlignedDimension Dim DefineAcadDimAngular As AcadDimAngular 'AcDb2LineAngularDimension '平面线性类 Dim DefineLine As AcadLine, DefineLineArray() As Variant 'AcDbLine Dim DefineArc As AcadArc 'AcDbArc Dim DefinePolyLine As AcadLWPolyline 'AcDbPolyline Dim Ent As AcadEntity 'Dim DrawingZombieEntity As AcadAttributeReference 'AcDbZombieEntity Dim LineCount As Integer '' LineCount = 1 For Each Ent In ThisDrawing.ModelSpace Select Case Ent.ObjectName Case "AcDbRadialDimension1" Set DefineAcadDimRadial = Ent With DefineAcadDimRadial Debug.Print .AltRoundDistance Debug.Print .AltSuppressLeadingZeros Debug.Print .AltSuppressTrailingZeros Debug.Print .AltSuppressZeroFeet Debug.Print .AltSuppressZeroInches Debug.Print .AltTextPrefix Debug.Print .AltTextSuffix Debug.Print .AltTolerancePrecision Debug.Print .AltToleranceSuppressLeadingZeros Debug.Print .AltToleranceSuppressTrailingZeros Debug.Print .AltToleranceSuppressZeroFeet Debug.Print .AltUnits Debug.Print .AltUnitsFormat Debug.Print .AltUnitsPrecision Debug.Print .AltUnitsScale Debug.Print .ArrowheadBlock Debug.Print .ArrowheadSize Debug.Print .ArrowheadType Debug.Print .CenterMarkSize Debug.Print .CenterType Debug.Print .DimensionLineColor Debug.Print .DimensionLineWeight Debug.Print .DimLineSuppress Debug.Print .Fit Debug.Print .ForceLineInside Debug.Print .FractionFormat Debug.Print .Layer 'Debug.Print .LeaderLength Debug.Print .LinearScaleFactor Debug.Print .Measurement Debug.Print .PrimaryUnitsPrecision Debug.Print .RoundDistance Debug.Print .SuppressZeroFeet Debug.Print .SuppressZeroInches Debug.Print .StyleName '文字部分 Debug.Print .TextColor Debug.Print .TextInside Debug.Print .TextInsideAlign Debug.Print .TextGap Debug.Print .TextHeight Debug.Print .TextMovement Debug.Print .TextOutsideAlign Debug.Print .TextOverride Debug.Print .TextPosition(0), .TextPosition(1), .TextPosition(2) Debug.Print .TextPrefix Debug.Print .TextRotation Debug.Print .TextStyle Debug.Print .TextSuffix Debug.Print .ToleranceSuppressZeroFeet Debug.Print .ToleranceSuppressZeroInches Debug.Print .UnitsFormat End With Case "AcDbMText" Debug.Print Ent.ObjectName Set DefineAcadMText = Ent Debug.Print TypeName(DefineAcadMText) Debug.Print DefineAcadMText.TextString With DefineAcadMText Debug.Print .ObjectID Debug.Print .TextString End With End Select Next Ent 'Debug.Print "", LineCount End Sub |
