查看: 1154|回复: 0
[求助]在CAD的vba编程中,如何让vba运行窗口隐藏,显示cad图形并选点?
发表于 2008-4-3 10:56:00 | 显示全部楼层 |阅读模式
附我的vba代码(有模块1和过程zfj),为啥运行会是僵死状态?
Public Sub zfj()
Dim AcadApp As AutoCAD.AcadApplication
Set AcadApp = GetObject(, "AutoCAD.Application")
Dim Mydocument As AcadDocument
Set Mydocument = AcadApp.ActiveDocument
Dim Myentity As AcadPolygonMesh
Dim Mysel As AcadSelectionSet
Dim fil_type(0) As Integer
Dim fil_data(0) As Variant
Dim Mycoordinates As Variant
    fil_type(0) = 0
    fil_data(0) = "PolygonMesh"
On Error Resume Next
If Not IsNull(Mydocument.SelectionSets.Item("Mysel")) Then
    Set Mysel = Mydocument.SelectionSets.Item("Mysel")
    Mysel.Delete
End If
Set Mysel = Mydocument.SelectionSets.Add("Mysel")
Dim i, j, k As Integer
Me.hide
Mysel.SelectOnScreen
Me.show
For Each Myentity In Mysel
    Mycoordinates = Myentity.Coordinates
Next
Open "D:\zfj\ory.dat" For Append As #1
For i = 0 To (j * 6 - 1) Step 6
Print #1, "gen zone brick size 1,1,1" & " &"
Print #1, "p0" & "(" & Round(Mycoordinates(i), 4) & "," & Round(Mycoordinates(i + 1), 4) & "," & Round(Mycoordinates(i + 2), 4) & ")&"
Print #1, "p1" & "(" & Round(Mycoordinates(i + 3), 4) & "," & Round(Mycoordinates(i + 4), 4) & "," & Round(Mycoordinates(i + 5), 4) & ")&"
Print #1, "p2" & "(" & Round(Mycoordinates(i), 4) & "," & Round(Mycoordinates(i + 1), 4) & "," & Round((Mycoordinates(i + 2) - 1), 4) & ")&"
Print #1, "p3" & "(" & Round(Mycoordinates(i + 6), 4) & "," & Round(Mycoordinates(i + 7), 4) & "," & Round(Mycoordinates(i + 8), 4) & ")&"
Print #1, "p4" & "(" & Round(Mycoordinates(i + 3), 4) & "," & Round(Mycoordinates(i + 4), 4) & "," & Round(Mycoordinates(i + 5) - 1, 4) & ")&"
Print #1, "p5" & "(" & Round(Mycoordinates(i + 6), 4) & "," & Round(Mycoordinates(i + 7), 4) & "," & Round(Mycoordinates(i + 8) - 1, 4) & ")&"
Print #1, "p6" & "(" & Round(Mycoordinates(i + 9), 4) & "," & Round(Mycoordinates(i + 10), 4) & "," & Round(Mycoordinates(i + 11), 4) & ")&"
Print #1, "p7" & "(" & Round(Mycoordinates(i + 9), 4) & "," & Round(Mycoordinates(i + 10), 4) & "," & Round(Mycoordinates(i + 11) - 1, 4) & ")"
Next
Print #1, ";*****************************"
Close #1
Mysel.Delete
end
End Sub
红色语句运行时有误,应如何改?请高人指教!
GMT+8, 2025-5-1 15:09 , Processed in 0.167874 second(s), 24 queries , Gzip On.
