附件是一个可读取任意线的顶点坐标,并已文本输出的程序,希望大家帮忙改改,让它一行一根线数据而不是一行一个点的数据,我所提取的多义线只有2~4点.写出数据要保证4个点.数据形式如下: (线)1,x1,y1z1,x2,y2,z2,x3,y3,z3,x4,y4,z4----(点与点间以逗号隔开) (线)2,x1,y1,z1,x2,y2,z2,x3,y3,z3,x4,y4,z4 (线)3,x1,y1,z1,x2,y2,z2,x3,y3,z3,9999,9999,9999--(点数不够以9999补满) ;;;;;;;;;;;;;;根据等高线标高取出数据 (DEFUN C:outh (/ SST H fi N I J K p NAME DXF TYPE_LINE XY_COUNT F x y PT1 D N1) (setq fi '((-4 . "<OR") ; Filter for ssget. (0 . "POLYLINE") (0 . "LWPOLYLINE") (0 . "SHAPE") (0 . "INSERT") (-4 . "OR>") ) ) (setq F (getfiled "写出文件" "" "txt" 1)) (SETQ F (OPEN F "w")) (PROMPT " \n选取等高线:") (SETQ SST (SSGET fi)) (SETQ N (SSLENGTH SST)) (SETQ J 0) (setq k 0) (setq p (getint " \n指定起始点号<1>:")) (IF (= NIL P) (setq p 1) ) (REPEAT N (SETQ NAME (SSNAME SST J)) (SETQ J (1+ J)) (SETQ DXF (ENTGET NAME)) (SETQ TYPE_LINE (CDR (ASSOC 0 DXF))) (COND ( (= TYPE_LINE "POLYLINE") (SETQ XY_COUNT (POLYLINE DXF NAME)) (setq i (length xy_count)) (setq k 0) (repeat i (setq y (nth k xy_count)) (setq h (nth 2 y)) (setq x (nth 1 y)) (setq y (nth 0 y)) (setq y (strcat (itoa P) "," (rtos Y 2 3) "," (rtos X 2 3) "," (rtos h 2 3) ) ) (write-line y f) (setq p (1+ p)) (setq k (1+ k)) (setq D D) (setq N1 N1) ) ) ((= TYPE_LINE "LWPOLYLINE") (SETQ H (CDR (ASSOC 38 DXF))) (SETQ XY_COUNT (LWPOLYLINE DXF)) (setq i (length xy_count)) (setq k 0) (repeat i (setq y (nth k xy_count)) (setq x (nth 1 y)) (setq y (nth 0 y)) (setq y (strcat (itoa P) "," (rtos X 2 3) "," (rtos Y 2 3) "," (rtos h 2 3) ) ) (write-line y f) (setq p (1+ p)) (setq k (1+ k)) (setq D D) (setq N1 N1) ) ) ((OR (= TYPE_LINE "SHAPE") (= TYPE_LINE "INSERT")) (SETQ PT1 (CDR (ASSOC 10 DXF))) (SETQ X (NTH 1 PT1)) (SETQ Y (NTH 0 PT1)) (SETQ H (NTH 2 PT1)) (setq y (strcat (itoa P) "," (rtos Y 2 3) "," (rtos X 2 3) "," (rtos h 2 3) ) ) (write-line y f) (setq p (1+ p)) (setq D D) (setq N1 N1) ) ) ) (close f) ) ;;;;;;;;;;;;;;;;;;; (defun POLYLINE (DXF E1 / XY E2 count_xy pd) (setq count_xy nil) (SETQ DXF (MEMBER (ASSOC 330 DXF) DXF)) (SETQ E2 (ENTNEXT E1)) (SETQ DXF (ENTGET E2)) (setq e1 (cdr (assoc 0 dxf))) (while (= e1 "VERTEX") (setq e1 (cdr (assoc 10 dxf))) (setq pd (cdr (assoc 70 dxf))) (if (/= pd 16) (setq count_xy (cons e1 count_xy)) ) (setq e1 e2) (SETQ E2 (ENTNEXT E1)) (SETQ DXF (ENTGET E2)) (setq e1 (cdr (assoc 0 dxf))) ) (setq COUNT_XY (reverse count_xy)) ) ;;;;;;;;;;;;;;;;;;;;;;; (defun LWPOLYLINE (DXF / XY COUNT_XY) (SETQ XY (ASSOC 10 DXF)) (SETQ COUNT_XY ()) (WHILE XY (SETQ DXF (MEMBER XY DXF)) (SETQ XY (CDR (ASSOC 10 DXF))) (SETQ DXF (CDR DXF)) (SETQ COUNT_XY (CONS XY COUNT_XY)) (SETQ XY (ASSOC 10 DXF)) ) (setq COUNT_XY (reverse COUNT_XY)) ) ;;;;;;;;;;;;; (defun ap-3d->2d (p1 / a b c) (setq a (nth 0 p1)) (setq b (nth 1 p1)) (setq p1 (list a b)) ) ;;;;;;;;;;;;;;;;; (DEFUN PDINDX (SST P1 / DIST INDX B JD N J K DIST_SST MAX_P1 MAX_P2 NAME INDX JD_NEAR MESG ) (SETQ J 0) (SETQ P1 (AP-3D->2D P1)) (SETQ N (SSLENGTH SST)) (REPEAT N (SETQ B (SSNAMEX SST J)) (SETQ JD (AP-3D->2D (NTH 0 (CDR (NTH 3 (NTH 0 B)))))) (SETQ NAME (NTH 1 (NTH 0 B))) (SETQ DIST (distance p1 jd)) (SETQ DIST_SST (CONS DIST DIST_SST)) (SETQ NAME_SST (CONS NAME NAME_SST)) (SETQ J (1+ J)) ) (SETQ J 0) (WHILE (/= J (- N 1)) (SETQ K 0) (WHILE (/= K (- N 1)) (SETQ MAX_P1 (NTH K DIST_SST)) (SETQ MAX_P2 (NTH (+ K 1) DIST_SST)) (IF (> MAX_P1 MAX_P2) (PROGN (SETQ B (CDR (MEMBER MAX_P2 DIST_SST))) (SETQ B (CONS MAX_P1 B)) (SETQ B (CONS MAX_P2 B)) (SETQ JD (- K 1)) (REPEAT K (SETQ MAX_P1 (NTH JD DIST_SST)) (SETQ B (CONS MAX_P1 B)) (SETQ JD (- JD 1)) ) (SETQ DIST_SST B) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (SETQ MAX_P1 (NTH K NAME_SST)) (SETQ MAX_P2 (NTH (+ K 1) NAME_SST)) (SETQ B (CDR (MEMBER MAX_P2 NAME_SST))) (SETQ B (CONS MAX_P1 B)) (SETQ B (CONS MAX_P2 B)) (SETQ JD (- K 1)) (REPEAT K (SETQ MAX_P1 (NTH JD NAME_SST)) (SETQ B (CONS MAX_P1 B)) (SETQ JD (- JD 1)) ) (SETQ NAME_SST B) ) ) (SETQ K (1+ K)) ) (SETQ J (1+ J)) ) (SETQ NAME_SST NAME_SST) ) ;
