查看: 1798|回复: 3
[求助]怎样用VBA对AutoCAD2004图纸文件进行加密?
发表于 2008-4-6 23:19:00 | 显示全部楼层 |阅读模式
大家好,怎样用VBA对AutoCAD2004图纸文件进行加密?手工加密只有用securityoptions命令,但文件多了太麻烦。
 楼主| 发表于 2008-4-7 00:20:00 | 显示全部楼层
哈,我在网上找到答案了:
Public Sub jm()
Dim oSecurity As AcadSecurityParams
Set oSecurity = New AcadSecurityParams
With oSecurity
.Action = AcadSecurityParamsType.ACADSECURITYPARAMS_ENCRYPT_DATA
.Algorithm = AcadSecurityParamsConstants.ACADSECURITYPARAMS_ALGID_RC4
.Comment = "My test"
.Issuer = "MTuersley"
.KeyLength = 40
.Password = UCase("mypassword")
.ProviderName = "Microsoft Base Cryptographic Provider v1.0"
.ProviderType = 1
.TimeServer = ""
End With
ActiveDocument.SaveAs "C:\MyDrawing.dwg", , oSecurity
End Sub
谢谢网上的牛人
 楼主| 发表于 2008-4-7 13:44:00 | 显示全部楼层
Delphi版:
unit Unit1;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, StdCtrls, ComObj, AutoCAD_TLB;
type
  TForm1 = class(TForm)
    Button1: TButton;
    Button2: TButton;
    Label1: TLabel;
    Button3: TButton;
    procedure Button1Click(Sender: TObject);
    procedure Button2Click(Sender: TObject);
    procedure Button3Click(Sender: TObject);
  private
    { Private declarations }
    acadapp:AcadApplication;
  public
    { Public declarations }
  end;
var
  Form1: TForm1;
implementation
{$R *.dfm}
{连接到AutoCAD}
procedure TForm1.Button1Click(Sender: TObject);
begin
  acadapp:=GetActiveOleObject('AutoCAD.Application') as AcadApplication;
end;
{加密AutoCAD图形文件}
procedure TForm1.Button2Click(Sender: TObject);
var
  lx:AcadSecurityParams;
begin
  lx:=acadapp.GetInterfaceObject('AutoCAD.SecurityParams.16') as AcadSecurityParams;
  lx.Action:=ACADSECURITYPARAMS_ENCRYPT_DATA;
  lx.Algorithm:=ACADSECURITYPARAMS_ALGID_RC4;
  lx.Comment:='My test';
  lx.Issuer:='MTuersley';
  lx.KeyLength:=40;
  lx.Password:=UpperCase('abc');
  lx.ProviderName:='Microsoft Base Cryptographic Provider v1.0';
  lx.ProviderType:=1;
  lx.TimeServer:='';
  acadapp.ActiveDocument.SaveAs('c:\1.dwg',ac2004_dwg,lx);
end;
{打开加密文件}
procedure TForm1.Button3Click(Sender: TObject);
begin
  acadapp.Documents.Open('c:\1.dwg',1,'abc');
end;
end.
发表于 2008-4-16 10:46:00 | 显示全部楼层
请问楼主,这样加密后还可以打开浏览吗?
有没有这样的代码可以给我一个吗?
GMT+8, 2025-2-22 16:38 , Processed in 0.178720 second(s), 23 queries , Gzip On.
