- ;;我用以下方法判断指定图层在视口中是否被冻结
- (defun lt:viewPort-layer-freeze (vp lay)
- (and (member (cons 331 (tblobjname "layer" lay)) (entget vp)))
怎样不用command,设置图层在视口中冻结或解冻- ;;;如下解冻的方法无效,请教各位
- (defun test (vp lay)
- (entmod (vl-remove-if
- '(lambda (x) (and (= (car x) 331) (eq (cdr x) (tblobjname "layer" lay)))) (entget vp)
