查看: 1437|回复: 1
由一条线段和圆弧组成的半圆,应该如何填充颜色
发表于 2008-4-15 16:27:00 | 显示全部楼层 |阅读模式
代码如下:
Dim varCenter(0 To 2) As Double
Dim varFirst_1(0 To 2) As Double
Dim varSecond_1(0 To 2) As Double
Dim varThird_1(0 To 2) As Double
Dim varFirst_2(0 To 2) As Double
Dim varSecond_2(0 To 2) As Double
Dim varThird_2(0 To 2) As Double
Dim dblRadius As Double
Dim dblAngle As Double
Dim varRegions As Variant
Dim objEnt() As AcadEntity
varCenter(0) = 1000
varCenter(1) = 1000
varCenter(2) = 0
dblRadius = 100
dblAngle = 3.1415926
With ThisDrawing.ModelSpace
    ReDim objEnt(2)
    Set objEnt(0) = .AddArc(varCenter, dblRadius * 0.5, dblAngle, 0)
    Set objEnt(1) = .AddLine(objEnt(0).StartPoint, objEnt(0).EndPoint)
    Set objEnt(2) = .AddPoint(varCenter)
    varRegions = .AddRegion(objEnt)
End With
ZoomAll
已经生成了Region,但是怎么为这个面域填充颜色呢?
 楼主| 发表于 2008-4-23 10:33:00 | 显示全部楼层
哦,这个问题我自己已经解决了。方法如下:
对自定义的图形进行颜色填充应该使用Hatch,Hatch有个设置外框的方法,Hatch还有Color属性。
GMT+8, 2025-2-22 16:35 , Processed in 0.168952 second(s), 24 queries , Gzip On.
