小弟才刚刚起步自学LISP语言,希望高手帮忙注解!!下面是提取线坐标的程序, (defun c:outcor(/ filename file entname ptlist index pt str) (setq OutCorFileIndex (if OutCorFileIndex OutCorFileIndex 1) filename (strcat (getvar "dwgprefix") "zb" (itoa OutCorFileIndex)".txt") OutCorFileIndex(1+ OutCorFileIndex) file (open filename "w") ) (setq entname (car(entsel)) ptlist (vl-remove-if '(lambda(x) (/= (car x) 10)) (entget entname)) index 0 ) (repeat (length ptlist) (setq pt (nth index ptlist) str (strcat (itoa (1+ index)) ",1,1," (itoa (1+ index)) "," (rtos (caddr pt) 2 3) ","(rtos (cadr pt) 2 3)) index (1+ index) ) (write-line str file) ) (close file) (alert (strcat "你的坐标文件保存在" filename "请查看")) )
