查看: 1440|回复: 3
自动填充的,出错了,帮忙看看!!
发表于 2008-4-17 21:54:00 | 显示全部楼层 |阅读模式
Sub test()
    Dim hatchObj As AcadHatch
    Dim patternName As String
    Dim PatternType As Long
    Dim bAssociativity As Boolean
    Dim outerLoop(0 To 0) As AcadEntity
    ' 定义图案填充
    patternName = "ANSI31"
    PatternType = 0
    bAssociativity = True
    ' 当前图纸的实体数目
    Dim n As Long
    n = ThisDrawing.ModelSpace.Count
    ' 调用BOUNDARY命令获取某一点处的边界
    Dim Pt As Variant
    Pt = ThisDrawing.Utility.GetPoint(, "指定内部点: ")
    ThisDrawing.SendCommand "_-Boundary" & vbCr & Pt(0) & "," & Pt(1) & vbCr & vbCr
    ' 如果存在边界,则会生成新的实体
    Dim lwpLineObj As AcadLWPolyline
    If ThisDrawing.ModelSpace.Count > n Then
        Set lwpLineObj = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
        MsgBox lwpLineObj.Area
'        lwpLineObj.Delete
        lwpLineObj.Closed = True
    Else
        MsgBox "未发现有效的边界。"
    End If
    outerLoop(0) = lwpLineObj
    hatchObj.AppendOuterLoop (outerLoop)
    hatchObj.Evaluate
    ObjDoc.Regen True
End Sub
 楼主| 发表于 2008-5-8 12:37:00 | 显示全部楼层
解决了,
需要加Boundary命令前加个zoomall命令
发表于 2008-5-9 18:47:00 | 显示全部楼层
我想楼主个问题
在对面域填充时
当面域为不连续或为环状时则不能正常填充(利用快速选择能选中图案填充,就是不能显示)
发表于 2008-5-9 19:14:00 | 显示全部楼层
Dim i As Long
Dim patternType As Long
Dim assocVar As Boolean
Dim eNt As AcadEntity
Dim sset As AcadSelectionSet
Dim outerLoop1(0 To 0) As AcadEntity
Dim n As Long
Dim Pt As Variant
patternName = "SOLID"
patternType = acHatchPatternTypePreDefined
assocVar = True
   Set outerLoop1(0) = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
Else
   MsgBox "未发现有效的边界。"
End If
 Set sset = ThisDrawing.SelectionSets.Add("ss7")
 sset.AddItems outerLoop1
For Each eNt In sset
   Set outerLoop(0) = eNt
   Set hatchObj = ThisDrawing.ModelSpace.AddHatch(patternType, patternName, assocVar)
   hatchObj.Evaluate
Next
sset.Delete
ThisDrawing.Regen True
GMT+8, 2025-5-1 15:29 , Processed in 0.189312 second(s), 23 queries , Gzip On.
