查到原因了,是少了一个括号
 - ;;;标准输入对话框
- ;;;调用形式 (InputBox 显示的对话框名称 '( ( "editbox显示的说明" "editbox显示值" "editbox显示宽度") ...) )
- ;;;注意,调用参数均为字符串形式
- ;;;返回值为与输入表长度相等的字符串列表
- ;;;注意:以下代码未对输入代码格式进行检查,有需要时,需人加入格式检查的代码
- (defun InputBox (strDialogName EditBoxDefList
- / ResultList fStream
- dclname tempFileName fileN
- fileStream templist i
- dclid n
- (defun GetInput (len / i)
- (setq i 1
- ResultList
- nil
- (repeat len
- (setq ResultList
- (append ResultList (list (get_tile (itoa i))))
- (setq i (1+ i))
- (setq tempFileName (vl-filename-mktemp "dcltmp.dcl"))
- (setq fileN (open tempFileName "w"))
- (setq fileStream
- (list
- "InputBox:dialog {\n"
- (strcat "label =\"" strDialogName "\";\n")
- (setq i 0)
- (repeat (length EditBoxDefList)
- (setq templist (nth i EditBoxDefList))
- (setq fileStream
- (append fileStream
- (list
- ":edit_box{\n"
- "allow_accept = true ;\n"
- (strcat "edit_width =" (caddr templist) ";\n")
- "fixed_width = true ;\n"
- (strcat "key =\"" (itoa (1+ i)) "\";\n")
- (strcat "label=\"" (car templist) "\";\n")
- (strcat "value=\"" (cadr templist) "\";\n")
- (setq i (1+ i))
- (setq fileStream
- (list
- "ok_cancel;\n"
- "}\n"
- (foreach n
- fileStream
- (princ n fileN)
- (close fileN)
- (setq dclname tempFileName)
- (setq dclid (load_dialog dclname))
- (if (not (new_dialog "InputBox" dclid ""))
- (progn (alert "对话框加载失败!") (exit))
- (action_tile
- "accept"
- "(GetInput (length EditBoxDefList) ) (done_dialog 1)"
- (start_dialog)
- (unload_dialog dclid)
- (vl-file-delete dclname)
- ResultList
