查看: 2416|回复: 2
[求助]怎么提取多段线的顶点坐标值?
发表于 2008-4-20 16:28:00 | 显示全部楼层 |阅读模式
请问各位大侠,能否把当前选择的多段线的顶点坐标值提取出来,并保存在记事本里
发表于 2008-4-20 19:46:00 | 显示全部楼层
Sub Example_Coordinate()
    ' This example creates a polyline in model space and
    ' queries and changes the coordinate in the first index position.
    Dim plineObj As AcadPolyline
    Dim points(0 To 14) As Double
    ' Define the 2D polyline points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    ' Create a lightweight Polyline object in model space
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ZoomAll
    ' Find the coordinate in the first index position
    Dim coord As Variant
    coord = plineObj.Coordinate(0)
    MsgBox "The coordinate in the first index position of the polyline is: " & coord(0) & ", " _
        & coord(1) & ", " & coord(2)
    ' Change the coordinate
    coord(0) = coord(0) + 1
    plineObj.Coordinate(0) = coord
    plineObj.Update
    ' Query the new coordinate
    MsgBox "The coordinate in the first index position of the polyline is now: " & coord(0) & ", " _
        & coord(1) & ", " & coord(2)'这里就是你要的点坐标
End Sub
Open "c:\点坐标.txt" For Output As #1
Print #1, "你好"
Print #1, "hello"
Close #1
输出"你好"到txt第一行输出"hello"到txt第二行
 楼主| 发表于 2008-4-21 08:56:00 | 显示全部楼层
太感谢了!!
GMT+8, 2026-1-25 18:48 , Processed in 0.556137 second(s), 23 queries , Gzip On.
