查看: 4794|回复: 16
***lisp与DCL文件的衔接***已解决,感谢ZZXXQQ斑竹帮忙
发表于 2008-4-21 20:06:00 | 显示全部楼层 |阅读模式
LISP是麻烦坛里的弟兄编的,稍加了点信息.对话框是自己编的,请大家将LISP与DCL衔接,实现功能如下:
1."起始号","外径","节数","弯模"是由用户填写,且下次显示时默认上次输入的值.
2.点击"选择"时关闭对话框,由用户选择多义线,选完点鼠标右键恢复对话框,将要保存的信息显示在"LIST"中
3.如果用户点"继续选择"时关闭对话框,由用户选择多义线,选完点鼠标右键恢复对话框,将新选的数据叠加到之前的数据中
4.如果用户二次点"选择"时关闭对话框,由用户选择多义线,选完点鼠标右键恢复对话框,将新选的数据替换原有数据
5.用户点"保存数据",出现"浏览"对话框,由用户指定文件保存路径.
6."确定"--文件输出,"取消"--退出程序
对话框文件:
getdata : dialog {
                  label = "提取多义线顶点坐标";
                  : boxed_column {
                                  label = "列表";
                                   : list_box {
                                               key = "list";
                                               width = 20;
                                               height = 20;
                                   : column {
                                             : row {
                                                    : edit_box {
        label = "起始号:";
        key = "P";
        edit_width = 3;
                                                    : edit_box {
        label = "  外  径:";
        key = "D";
        edit_width = 6;
                                                    : row {
                                                           : edit_box {
        label = "  分:";
        key = "N";
        edit_width = 3;
                                                           : text {
        label = "节";
                                                    : edit_box {
        label = "  弯  模:";
        key = "R";
        edit_width = 6;
                 :row {
                       :retirement_button
                                    label = "选择..";
                                    key = "xz";
                       :retirement_button
                                    label = "继续选择..";
                                    key = "jxxz";
                       :retirement_button
                                    label = "保存数据..";
                                    key = "bcsj";
                        ok_cancel;
LISP文件:
(DEFUN C:getdata (/     SST   H  fi    N     I    J  K     p
        NAME  DXF   TYPE_LINE   XY_COUNT    F  x     y
        PT1   D    N1 R
  (setq fi '((0 . "*POLYLINE")))
  (setq F (getfiled "写出文件" "" "pxt" 1))
  (SETQ F (OPEN F "w"))
  (command "_layer" "off" "pipesolid" "")
  (command "_layer" "ON" "pipeline" "")
  (PROMPT " \n选多义线:")
  (SETQ SST (SSGET fi))
  (SETQ J 0)
  (setq k 0)
  (setq p (getint " \n序号<1>:"))
  (IF (= P nil)
    (setq p 1)
  (setq D (getint " \n外径<508>:"))
  (IF (= nil D)
    (setq D 508)
  (setq R (getint " \n弯模<500>:"))
  (IF (= nil R)
    (setq R 500)
  (setq N1 (getint " \n分几节<4>:"))
  (IF (= nil N1)
    (setq N1 4)
  (REPEAT (SSLENGTH SST)
    (SETQ NAME (SSNAME SST J))
    (SETQ J (1+ J))
    (SETQ DXF (ENTGET NAME))
    (SETQ TYPE_LINE (CDR (ASSOC 0 DXF)))
    (SETQ XY_COUNT (EVAL (READ (STRCAT "(" TYPE_LINE " DXF NAME)"))))
    (setq i (length xy_count))
    (setq k 0)
    (princ "\n" f)
    (princ p f)
    (princ "," f)
    (princ D f)
    (princ "," f)
    (princ R f)
    (princ "," f)
    (princ N1 f)
    (princ "," f)
    (repeat i
      (setq y (nth k xy_count))
      (setq h (nth 2 y))
      (setq x (nth 1 y))
      (setq y (nth 0 y))
      (setq y (strcat (IF (> k 0)
        (rtos Y 2 3)
        (rtos X 2 3)
        (rtos h 2 3)
      (princ y f)
      (setq k (1+ k))
    (setq p (1+ p))
  (close f)
  (prompt  (strcat "\n管子数据已经输出完毕;共保存<"(itoa (- P 1))">根管"))
  (command "_layer" "on" "pipesolid" "")
  (command "_layer" "off" "pipeline" "")
(defun POLYLINE (DXF E1 / XY E2 count_xy pd)
  (setq count_xy nil)
  (SETQ DXF (MEMBER (ASSOC 330 DXF) DXF))
  (SETQ E2 (ENTNEXT E1))
  (SETQ DXF (ENTGET E2))
  (setq e1 (cdr (assoc 0 dxf)))
  (while (= e1 "VERTEX")
    (setq e1 (cdr (assoc 10 dxf)))
    (setq pd (cdr (assoc 70 dxf)))
    (if (/= pd 16)
      (setq count_xy (cons e1 count_xy))
    (setq e1 e2)
  (setq COUNT_XY (reverse count_xy))
谢谢
发表于 2021-2-14 11:59:24 | 显示全部楼层
路过看看,学习学习
 楼主| 发表于 2008-4-24 22:16:00 | 显示全部楼层
麻烦大家务必出手相助啊,拜托了
 楼主| 发表于 2008-4-27 11:08:00 | 显示全部楼层
怎么没人回帖啊....................................................
发表于 2008-4-27 11:18:00 | 显示全部楼层
列表框中数据什么格式?
 楼主| 发表于 2008-4-28 01:21:00 | 显示全部楼层
谢谢ZZXXQQ斑竹的回复,
"列表框中数据"其实就是即将写入*.PXT中的数据,也就是希望预览*.PXT数据以便及时核对和修改数据.
谢谢
 楼主| 发表于 2008-4-29 00:34:00 | 显示全部楼层
假如大家觉得实现预览*.PXT数据这个功能太麻烦,可以不要了,求大家帮助实现其他功能吧.....
 楼主| 发表于 2008-4-29 23:37:00 | 显示全部楼层
决心继续求助,直到解决为止.....
发表于 2008-4-30 19:44:00 | 显示全部楼层
再试试看
游客,本帖隐藏的内容需要发帖数高于 10 才可浏览,你当前发帖数只有 0
发表于 2008-4-30 21:25:00 | 显示全部楼层
ZZXXQQ
you have two down son
 楼主| 发表于 2008-4-30 22:48:00 | 显示全部楼层
感谢ZZXXQQ斑竹,发现你的程序有如下问题:
1.提取出的多段线"序号"不会自动"+1",输入1就一直提取1
2.初次选完多段线后点"继续选择"是将新选数据叠加到前面数据后
3.初次选完多段线后再点"选择"是将新选数据替换前面数据(即将前面数据清空后再输入新选数据)
4.希望将"保存数据"与"确定"功能合二为一
诚心期待你的方案.谢谢
GMT+8, 2025-10-2 02:31 , Processed in 0.249442 second(s), 30 queries , Gzip On.
