查看: 1922|回复: 4
[求助]如何求出两条曲线的交点?
发表于 2008-4-25 14:36:00 | 显示全部楼层 |阅读模式
Autolisp中如何返回两条曲线(圆弧或者多义线)的交点?
发表于 2008-4-25 17:33:00 | 显示全部楼层
在坛里搜索一下,有许多
 楼主| 发表于 2008-4-25 18:34:00 | 显示全部楼层
谢了。我试试
发表于 2008-4-25 19:14:00 | 显示全部楼层
;;;获取两条直线的交点
(defun c:ff ()
  (mycopyright)
  (vl-load-com)
  (setq ent1 (entsel "\n选择第一条曲线:"))
  (setq ent2 (entsel "\n选择第二条曲线:"))
  (setq ent_1 (car ent1)
 ent_2 (car ent2)
  (setq int_list nil)
  (setq ax_ent_1 (vlax-ename->vla-object ent_1)
 ax_ent_2 (vlax-ename->vla-object ent_2)
  (setq intpoints (vla-intersectwith ax_ent_1 ax_ent_2 acextendnone))
  (setq intpoints (vlax-variant-value intpoints))
  (if (> (vlax-safearray-get-u-bound intpoints 1) 0)
      (setq i 0)
      (setq j 0)
      (setq disp "")
      (repeat
 (/ (+ 1
       (- (vlax-safearray-get-u-bound intpoints 1)
   (vlax-safearray-get-l-bound intpoints 1)
    3
  (setq
    disp (list
    (vlax-safearray-get-element intpoints j)
    (vlax-safearray-get-element intpoints (+ 1 j))
    (vlax-safearray-get-element intpoints (+ 2 j))
  (setq i (+ 2 i)
        j (+ 3 j)
  (setq int_list (append int_list (list disp)))
  (setq int_list int_list)
发表于 2008-4-27 19:20:00 | 显示全部楼层
  1. (defun c:n (/ obj p1 p2 p3 li)
  2.   (setq obj (vlax-ename->vla-object (car (entsel "\ncurve: ")))
  3. p1  (trans (getpoint "\npoint 1: ") 1 0)
  4. p2  (trans (getpoint p1 "\npoint 2: ") 1 0)
  5. li  (vla-addline (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object) ) ) (vlax-3d-point p1) (vlax-3d-point p2) )
  6. p3  (vlax-invoke obj 'IntersectWith li acExtendNone)
  7.   )
  8.   (if p3
  9.     (vla-put-EndPoint li (vlax-3d-point (list (car p3) (cadr p3) (caddr p3))))
  10.     (vla-delete li)
  11.   )
  12.   (princ)
  13. )
GMT+8, 2025-5-14 00:37 , Processed in 0.167338 second(s), 26 queries , Gzip On.
