查看: 1306|回复: 1
[原创]PickFirstSSet改进
发表于 2008-5-11 21:05:00 | 显示全部楼层 |阅读模式
此函数用于VBA程序,先选择后操作 详见 原帖增添了简单的过滤功能
最理想的过滤方式应该是SS.Select acSelectionSetPrevious,,, FilterType, FilterData
就是不知道怎么样把PickfirstSelectionSet变成SelectionSetPrevious
  1. Public Function PickFirstSSet(Optional ByVal Type_Name As String) As AcadSelectionSet
  2.     On Error Resume Next
  3.     Dim SS As AcadSelectionSet
  4.     Dim Ent As AcadEntity
  5.     Set SS = ThisDrawing.PickfirstSelectionSet
  6.     If SS.Count = 0 Then
  7.         ThisDrawing.Utility.Prompt "请选择对象:" & vbCrLf
  8.         SS.SelectOnScreen
  9.     End If
  10.     If Type_Name <> "" Then
  11.         Dim DelSS() As AcadEntity
  12.         Dim i As Integer
  13.         For Each Ent In SS
  14.             If InStr(Type_Name, TypeName(Ent)) <= 0 Then
  15.                 ReDim Preserve DelSS(i)
  16.                 Set DelSS(i) = Ent
  17.                 i = i + 1
  18.             End If
  19.         Next
  20.         SS.RemoveItems DelSS
  21.     End If
  22.     Set PickFirstSSet = SS
  23. End Function
简单示例(只修改文字对象的颜色):
  1. Sub CC()
  2.      Dim Ent As AcadEntity
  4.      Set SS = PickFirstSSet("IAcadText2")
  5.      For Each Ent In SS
  6.          Ent.color = acGreen
  7.      Next
  8. End Sub
 楼主| 发表于 2008-5-12 11:40:00 | 显示全部楼层
今天使用时发现错误: Visual LISP command document mismatch: TB
GMT+8, 2025-2-21 03:11 , Processed in 0.146886 second(s), 23 queries , Gzip On.
