 - ;自动加载VBA程序的函数
- (vl-load-com)
- (defun AutoVBALoad (app cmdliste stat / qapp strcmd)
- (setq qapp (strcat """ app """))
- (mapcar
- '(lambda (cmd / nom_cmd dot nodotcmd)
- (progn
- (setq dot (vl-string-search "." cmd))
- (if dot
- (setq nodotcmd (substr cmd (+ dot 2)))
- (setq nodotcmd cmd)
- (setq nom_cmd (strcat "C:" nodotcmd))
- (if (member stat '(0 1 2 3 4 5 6 7))
- (setq strcmd
- (strcat "(AddCommandsInMDI ""
- nodotcmd
- nom_cmd
- nodotcmd
- (itoa stat)
- (setq strcmd "")
- (eval
- (read
- (strcat
- "(defun " nom_cmd
- "(/ app)" "(if (setq app(fdvbfile "
- qapp "))"
- "(progn(vla-runmacro (vlax-get-acad-object) (strcat app "!"
- cmd ""))"
- strcmd ")"
- "(nodvbfile " qapp
- "))" "(princ ))"
- cmdliste
- (princ)
其中vlax-add-cmd 改成了 AddCommandsInMDI 需要配合下面两个函数: - (defun AddCommandsHelper (CallingReactor CommandList / return ok)
- (foreach x *AddCommandsList*
- (if (and (member (type (eval (caddr x))) '(SUBR USUBR EXRXSUBR))
- (setq ok (apply 'vlax-add-cmd (cdr x)))
- (setq return (cons ok return))
- return
- (defun AddCommandsInMDI (lst / old)
- (foreach x lst
- (vlax-remove-cmd (car x))
- (if (setq old (assoc (strcase (car x)) *AddCommandsList*))
- (setq *AddCommandsList*
- (subst (cons (strcase (car x)) x)
- old
- *AddCommandsList*
- (cons (cons (strcase (car x)) x)
- *AddCommandsList*
- (if (not InitializeAddCommandsReactor)
- (setq InitializeAddCommandsReactor
- (vlr-docmanager-reactor
- "InitializeAddCommands"
- '((:vlr-documentBecameCurrent . AddCommandsHelper))
- (AddCommandsHelper NIL NIL)
这样就可以避免两个文档用一个命令调用VBA程序的错误了,这个方法是网上搜索来的。我学校里学的是VB,毕业自己看VBA的书,LISP是一窍不通,多亏网络的强大啊。这个bug老早就有人提过了,那个至顶的帖子几年了居然还没有解决方案,明经是不是没落了?
