查看: 1581|回复: 3
SCR文件不能执行,各位大大帮帮看下
发表于 2008-5-13 13:11:00 | 显示全部楼层 |阅读模式
enerating model.
AutoCAD menu utilities loaded.
Command: Specify opposite corner:
Command: scr SCRIPT
Command: osnap Enter list of object snap modes: off
Command: LIMITS
Reset Model space limits:
Specify lower left corner or [ON/OFF] <0.0000,0.0000>: -500,-500
Specify upper right corner <420.0000,297.0000>: 500,500
Command: ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window] <real time>: A
Regenerating model.
Command: LAYER
Current layer:  "0"
Enter an option
[?/Make/Set/New/ON/OFF/Color/Ltype/LWeight/Plot/Freeze/Thaw/LOck/Unlock/stAte]:
N
Enter name list for new layer(s): 1
Enter an option
C
Enter color name or number (1-255): 7
Enter name list of layer(s) for color 7 (white) <0>: 1
Enter an option
N
Enter name list for new layer(s): 2
Enter an option
C
Enter color name or number (1-255): 1
Enter name list of layer(s) for color 1 (red) <0>: 2
Enter an option
N
Enter name list for new layer(s): 3
Enter an option
C
Enter name list of layer(s) for color 1 (red) <0>: 3
Enter an option
N
Enter name list for new layer(s): 4
Enter an option
C
Enter color name or number (1-255): 3
Enter name list of layer(s) for color 3 (green) <0>: 4
Enter an option
N
Enter name list for new layer(s): 5
Enter an option
C
Enter name list of layer(s) for color 3 (green) <0>: 5
Enter an option
N
Enter name list for new layer(s): 6
Enter an option
C
Enter name list of layer(s) for color 3 (green) <0>: 6
Enter an option
N
Enter name list for new layer(s): 7
Enter an option
C
Enter name list of layer(s) for color 3 (green) <0>: 7
Enter an option
n
Enter name list for new layer(s): 8 Enter an option
c
Enter name list of layer(s) for color 3 (green) <0>: 8
Enter an option
L
Enter loaded linetype name or [?] <Continuous>: DIVIDE2
Enter name list of layer(s) for linetype "DIVIDE2" <0>: 8
Enter an option
L
Enter loaded linetype name or [?] <Continuous>: dashed2
Enter name list of layer(s) for linetype "DASHED2" <0>: 2
Enter an option
L
Enter loaded linetype name or [?] <Continuous>: DASHDOTX2
Enter name list of layer(s) for linetype "DASHDOTX2" <0>: 4
Enter an option
L
Enter name list of layer(s) for linetype "DASHDOT" <0>: 5
Enter an option
L
Enter loaded linetype name or [?] <Continuous>: DASHDOT2
Enter name list of layer(s) for linetype "DASHDOT2" <0>: 6 Enter an option
Command: LTSCALE Enter new linetype scale factor <1.0000>: 4
Regenerating model.
Command: dim
标注:dimtih 输入标注变量的新值 <Off>:off
标注:dimtoh 输入标注变量的新值 <Off>:off
标注:dimtad 输入标注变量的新值 <1>:1
标注:dimasz 输入标注变量的新值 <2.5000>:0
标注:dimexo 输入标注变量的新值 <0.6250>:.09
标注:dimexe 输入标注变量的新值 <1.2500>:.09
标注:dimtsz 输入标注变量的新值 <0.0000>:.09
标注:dimtxt
输入标注变量的新值 <2.5000>:0.2200
标注:dimclrt
输入标注变量的新值 <BYBLOCK>:2
标注:dimdli 输入标注变量的新值 <3.7500>:0.38
标注:dimgap 输入标注变量的新值 <0.6250>:.09
标注:dimtofl 输入标注变量的新值 <On>:on
标注:dimscale 输入标注变量的新值 <1.0000>:2.2
标注:exit
Command: style Enter name of text style or [?] <Standard>: standard
Existing style.
Specify full font name or font filename (TTF or SHX) <txt>: SIMPLEX,STWHZ
D:\Program Files\cad2002\fonts\STWHZ is a normal text font file, not a big-font
file.
file.
Specify height of text <0.0000>: 0 Specify width factor <1.0000>: 0.7
Specify obliquing angle <0>: 0 Display text backwards? [Yes/No] <N>: n Display
text upside-down? [Yes/No] <N>: n
Vertical? <N> viewres
Yes or No, please.
Vertical? <N> *Cancel*
 楼主| 发表于 2008-5-13 13:15:00 | 显示全部楼层
CAD  SCR文件在ATUOCAD2002中不能执行, 上面是CAD中显示的词语,各位帮忙看下是怎么回事 小弟在此拜谢啦
下面的附件是SCR文件
发表于 2008-5-13 14:37:00 | 显示全部楼层
问题应该是出现在上面的 Specify full font name or font filename (TTF or SHX) &lt;txt&gt;: SIMPLEX,STWHZ 这里. 接下来的提示是说 STWHZ is a normal text font file, not a big-font file. 意思是 STWHZ 是个普通的 font 字体文件, 不是汉字类的大字体文件. 所以, 解决的方法是你可以根据自己系统里有的汉字类大字体文件, 把 STWHZ 给替换下, 比如可以是 gbcbig.shx 这个 ACAD 自带的汉字类大字体文件.
 楼主| 发表于 2008-5-14 21:59:00 | 显示全部楼层
谢谢提醒~  就是字体的缘故~~ 呵呵  搞定了
GMT+8, 2025-8-19 09:01 , Processed in 0.172537 second(s), 27 queries , Gzip On.
