查看: 1340|回复: 3
[求助]如何取消"Make Multiple Copies with Grips"?
发表于 2008-5-13 13:29:00 | 显示全部楼层 |阅读模式
下面是CAD2008的帮忙文件里关于"Make Multiple Copies with Grips"的说明,,,问题是我并不想要这样的功能,,,请教各位网友,,,如何取消?!
You can also make multiple copies by holding down CTRL as you select the first point!取消这一功能!在拖动节点时按下ctrl,我并不想复制!
图片点击可在新窗口打开查看Concept图片点击可在新窗口打开查看图片点击可在新窗口打开查看Procedure图片点击可在新窗口打开查看图片点击可在新窗口打开查看Quick Reference图片点击可在新窗口打开查看
You can create multiple copies of objects as you modify them with any of the grip modes.
For example, by using the Copy option, you can rotate the selected objects, leaving copies at each location you specify with the pointing device.
图片点击可在新窗口打开查看
You can also make multiple copies by holding down CTRL as you select the first point. For example, with the Stretch grip mode, you can stretch an object, such as a line, and then copy it to any point in the drawing area. Multiple copies continue being made until you turn off grips.
NoteWhen you use grips to make multiple copies of an annotative object that contains multiple scale representations, only the current scale representation is copied.
Define an Offset Snap or a Rotation Snap
You can place multiple copies at regularly spaced intervals with an offset snap. The offset snap is defined by the distance between an object and the next copy. In the lighting layout below, the first copy of the light fixture symbol is placed at an offset of two units. All subsequent copies are then placed two units apart.
图片点击可在新窗口打开查看
If you hold down CTRL while you select multiple copy points with the pointing device, the graphics cursor snaps to an offset point based on the last two points you selected. In the illustration below, the midpoint of line 1 is at coordinate 8,5. Based on that midpoint, line 2 was copied using the CTRL key and Stretch grip mode; its midpoint is at 9,5. The third line snaps to an offset based on the coordinate values 10,5.
图片点击可在新窗口打开查看
Similarly, you can place multiple copies at angular intervals around a base grip with a rotation snap. The rotation snap is defined as the angle between an object and the next copy when you are using Rotate grip mode. Hold down CTRL to use the rotation snap.
图片点击可在新窗口打开查看
发表于 2008-5-13 14:43:00 | 显示全部楼层
不太明白你的意思, 不想用这个功能, 不用就是. 如果是不想使用 Grips 功能的话, 那可以在下拉菜单 Tools.Options 对话框的 Selection 页中, 取消 Grips 功能. 如果是要在 Grips 功能里, 进行操作时将 Ctrl 按下的复制选项转换为其它的, 恐怕为难了.
 楼主| 发表于 2008-5-13 19:31:00 | 显示全部楼层
"...如果是要在 Grips 功能里, 进行操作时将 Ctrl 按下的复制选项转换为其它的, 恐怕为难了."
我并不想将 Ctrl 按下的复制选项转换为其它,而是按下后,不想复制!
因为我的CAD中的"按下Ctrl"已经设置成其它功能了!因此现在就造成冲突了!
 楼主| 发表于 2008-5-15 07:43:00 | 显示全部楼层
几天过去了,还是没人能回答....
斑主,能不能帮忙解决一下!?
GMT+8, 2025-8-19 09:04 , Processed in 0.169496 second(s), 26 queries , Gzip On.
