查看: 1186|回复: 2
为何取不到字符串
发表于 2008-5-13 18:24:00 | 显示全部楼层 |阅读模式
 Function getattributes(ByVal ThisDrawing As AcadDocument, ByVal dwgname As String, ByVal acadapp As AcadApplication)
        Dim insertionPnt(0 To 2) As Double
        Dim blockRefObj As AcadBlockReference
        insertionPnt(0) = 0.0# : insertionPnt(1) = 0.0# : insertionPnt(2) = 0.0#
        'insertionPnt(0) = 2.0# : insertionPnt(1) = 2.0# : insertionPnt(2) = 0
        blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, dwgname, 1.0#, 1.0#, 1.0#, 0)
        '插入图形文件或当前图形中已定义的命名块。
        ' Get the attributes for the block reference
        Dim varAttributes As Object
        varAttributes = blockRefObj.GetAttributes
        ' Move the attribute tags and values into a string to be displayed in a Msgbox
        Dim strAttributes As String
        Dim I As Integer
        For I = LBound(varAttributes) To UBound(varAttributes)
            strAttributes = strAttributes & "  Tag: " & varAttributes(I).TagString & _
                       "   Value: " & varAttributes(I).textString & "    "
            ' MsgBox(varAttributes(I).textString)
            ' MsgBox(varAttributes(I).TagString())
        Next
        MsgBox("The attributes for blockReference " & blockRefObj.Name & " are: " & strAttributes, , "GetAttributes Example")
        '文件的名字blockRefObj.Name
    End Function
varAttributes(I).TagString   不知道为什么  取不到任何字符串!
发表于 2008-5-13 23:32:00 | 显示全部楼层
函数应该有返回值
 楼主| 发表于 2008-5-14 07:36:00 | 显示全部楼层
不是 MsgBox("The attributes for blockReference " & blockRefObj.Name & " are: " & strAttributes, , "GetAttributes Example")
无法显示出来
GMT+8, 2024-11-26 09:50 , Processed in 0.154028 second(s), 23 queries , Gzip On.
