查看: 978|回复: 0
'how to get text object in model space ?
发表于 2008-5-14 08:01:00 | 显示全部楼层 |阅读模式
    Function TextString(ByVal ThisDrawing As AcadDocument, ByVal acadapp As AcadApplication)
        Dim textObj As AcadText
        Dim text As String
        Dim insertionPoint(0 To 2) As Double
        Dim height As Double
        ' Define the text object
        text = "jjjjjjj"
        insertionPoint(0) = 0.0# : insertionPoint(1) = 0.0# : insertionPoint(2) = 0.0#
        height = 5000
              ' Create the text object in model space
        textObj = ThisDrawing.ModelSpace.AddText(text, insertionPoint, height)
        acadapp.ZoomAll()
        ' Return the current text string for the object
        text = textObj.TextString
        MsgBox("The TextString property equals: " & text, vbInformation, "TextString 示例")
    End Function
这段代码是创建text object 在model space厘面 ,那么如何取得呢?帮助里面说访问路径是
访问途径:
ModelSpace.Item
  能不能给个范例 具体是如何访问的?
GMT+8, 2025-2-22 05:23 , Processed in 0.159214 second(s), 23 queries , Gzip On.
