试试,改颜色为当前层。 ----》 (defun c:gs (/ old_osmode old_cmdecho ss ssLine ssArc) (vl-load-com) (setq *AcadDocument* (vla-get-activeDocument (vlax-Get-Acad-Object))) (vla-StartUndoMark *AcadDocument*) (setq old_osmode (getvar "osmode") old_cmdecho (getvar "cmdecho") ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (setq ss (GetSelToUnite) ssLine (car ss) ssArc (cadr ss) ) (setvar "osmode" 0) (command ".ucs" "w") (if (> (sslength ssLine) 1) (UniteLine ssLine) ) (if (> (sslength ssArc) 1) (UniteArc ssArc) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (if (> (sslength ssLine) 0) (pEdit ssLine) ) (if (> (sslength ssArc) 0) (pEdit ssArc) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (setvar "osmode" old_osmode) (setvar "cmdecho" old_cmdecho) (vla-EndUndoMark *AcadDocument*) (prin1) ) (defun pedit (ss / i en vn startPt endPt ss1 ss2) (setq i 0) (repeat (sslength ss) (setq en (ssname ss i) i (1+ i) ) (if (and (not (null (entget en))) (not (vlax-curve-isClosed (setq vn (vlax-ename->vla-object en))))) (progn (setq startPt (vlax-curve-GetStartPoint vn) endPt (vlax-curve-GetEndPoint vn) ) (setq ss1 (ssget "_c" (polar startPt (* pi 0.25) 0.01) (polar startPt (* pi 1.25) 0.01))) (setq ss2 (ssget "_c" (polar endPt (* pi 0.25) 0.01) (polar endPt (* pi 1.25) 0.01))) (if (equal (strcase (vla-Get-ObjectName vn)) (strcase "AcDbPolyline")) (progn (vl-cmdf "pedit" en "j" ss1 ss2 "") (COMMAND "CHANGE" (entlast) "" "PROPERTIES" "la" (getvar "clayer") "")) (progn (vl-cmdf "pedit" en "y" "j" ss1 ss2 "" "")(COMMAND "CHANGE" (entlast) "" "PROPERTIES" "la" (getvar "clayer") "")) ) ) ) ) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun GetSelToUnite (/ ss1 ssArc ssLine ss1 ss i en ss2) (setq ss1 (ssget "x") ssArc (ssadd) ssLine (ssadd) ss (ssget '((0 . "line,lwpolyline,arc"))) i -1 ) (setvar "cmdecho" 0) (repeat (sslength ss) (setq en (ssname ss (setq i (1+ i)))) (if (equal (strcase (cdr (assoc 0 (entget en)))) (strcase "lwpolyline")) (command "explode" en) ) ) (setq ss2 (ssget "x") i -1 ) (repeat (sslength ss2) (setq en (ssname ss2 (setq i (1+ i)))) (if (or (not (ssmemb en ss1)) (ssmemb en ss)) (cond ((equal (cdr (assoc 0 (entget en))) (strcase "line")) (ssadd en ssLine)) ((equal (cdr (assoc 0 (entget en))) (strcase "arc")) (ssadd en ssArc)) (t (princ "\n There is a error occured")) ) ) ) (list ssLine ssArc) ) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun UniteArc (ss / i en) (vla-StartUndoMark *AcadDocument*) ;;; (while (not (setq ss (ssget '((0 . "arc")))))) (setq i 0) (repeat (sslength ss) (setq en (ssname ss i) i (1+ i) ) (if (not (null (entget en))) (JoinArc en) ) ) (vla-EndUndoMark *AcadDocument*) ) ;;;;;;;;; (defun JoinArc (en / vn cenPt Radius AngLst i ss MinPt MaxPt StartAngle EndAngle em vm) (setq vn (vlax-ename->vla-object en) cenPt (cdr (assoc 10 (entget en))) Radius (vla-get-radius vn) AngLst '() i -1 ss (ssadd) ) (vla-GetBoundingBox vn 'MinPt 'MaxPt) (setq MinPt (vlax-safearray->list MinPt) MaxPt (vlax-safearray->list MaxPt) ) (setq ss (ssget "c" MinPt MaxPt (list '(0 . "arc") (append (list 10) cenPt) (cons 40 Radius))) ss (ssdel en ss) ) (if ss (progn (setq StartAngle (vla-Get-StartAngle vn) EndAngle (vla-Get-EndAngle vn) ) (if (< EndAngle StartAngle) (setq EndAngle (+ EndAngle (* pi 2.0))) ) (setq AngLst (append AngLst (list StartAngle) (list EndAngle))) (repeat (sslength ss) (setq em (ssname ss (setq i (1+ i))) vm (vlax-ename->vla-object em) StartAngle (vla-Get-StartAngle vm) EndAngle (vla-Get-EndAngle vm) ) (if (< EndAngle StartAngle) (setq EndAngle (+ EndAngle (* pi 2.0))) ) (setq AngLst (append AngLst (list StartAngle) (list EndAngle))) ) (setq AngLst (vl-sort AngLst '<)) (vl-cmdf "erase" ss "") (vla-put-StartAngle vn (car AngLst)) (vla-put-EndAngle vn (if (> (last AngLst) (* pi 2)) (- (last AngLst) (* pi 2)) (last AngLst) ) ) ) ) ) ;;;;;;;;;(setq aa (vlax-ename->vla-object (car (entsel)))) ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;; (defun UniteLine (ss / i en) (vla-StartUndoMark *AcadDocument*) ;;; (while (not (setq ss (ssget '((0 . "line")))))) (setq i 0) (repeat (sslength ss) (setq en (ssname ss i) i (1+ i) ) (if (not (null (entget en))) (JoinLine en) ) ) (vla-EndUndoMark *AcadDocument*) (prin1) ) (defun JoinLine (en / i lst_pt ang_en se ss em ang_em ssErase) (setq i 0 lst_pt '() ang_en (RetAng (angle (cdr (assoc 10 (entget en))) (cdr (assoc 11 (entget en))))) ;;; lst_pt (append lst_pt (list (cdr (assoc 10 (entget en)))) (list (cdr (assoc 11 (entget en))))) ) (setq lst_pt (car (setq tmp (GetPtLst en))) ssErase (cadr tmp) ) (if (> (length lst_pt) 2) (progn (cond ((or (equal ang_en 0.0 0.001) (equal ang_en 180.0 0.001)) (setq lst_pt (vl-sort lst_pt '(lambda (e1 e2) (< (car e1) (car e2))))) ) (t (setq lst_pt (vl-sort lst_pt '(lambda (e1 e2) (< (cadr e1) (cadr e2))))) ) ) (vla-put-startPoint (vlax-ename->vla-object en) (vlax-3d-point (car lst_pt))) (vla-put-endPoint (vlax-ename->vla-object en) (vlax-3d-point (last lst_pt))) (vl-cmdf "erase" ssErase "") ) ) ) ;;;;;;;;;;; (defun GetPtLst (en / en_10 en_11 ang_en ptLst ss i em em_10 em_11 ang_em ang_10 ang_11) (setq en_10 (cdr (assoc 10 (entget en))) en_11 (cdr (assoc 11 (entget en))) ang_en (RetAng (angle en_10 en_11)) ptLst (list en_10 en_11) ssErase (ssadd) ) (setq ss (ssget "c" en_10 en_11 '((0 . "line")))) (if (> (sslength ss) 1) (progn (setq i -1) (ssdel en ss) (repeat (sslength ss) (setq em (ssname ss (setq i (1+ i))) em_10 (cdr (assoc 10 (entget em))) em_11 (cdr (assoc 11 (entget em))) ang_em (RetAng (angle em_10 em_11)) ang_10 (RetAng (angle en_10 em_10)) ang_11 (RetAng (angle en_10 em_11)) ) (if (and (equal ang_en ang_em 0.001) (or (equal ang_en ang_10 0.001) (equal ang_en ang_11 0.001))) (setq ptLst (append ptLst (list em_10) (list em_11)) ssErase (ssadd em ssErase) ) ) ) ) ) (list ptLst ssErase) ) ;;;;;;;;;;; (defun RetAng (ang) (if (>= ang (- pi 0.0001)) (atof (angtos (- ang pi) 0 4)) (atof (angtos ang 0 4)) ) )
