我在做毕业设计,要求是由对话框选择数据然后进行自动绘图,现在程序写到第一步总是提示 错误: 参数类型错误: stringp 10 的错误 自己调试了,我觉得是我的图像按钮出了错误,但是我步确定,也步知道怎么改 大侠们帮帮忙,要交了... 问题2:编辑框中的数据怎样传递到后面的绘图程序中,我的程序的方法是对的吗? 希望大家解解难,谢谢了! (defun c:mjdg() (setvar "cmdecho" 0) (dcl_mjdg) (prinl) ) (defun dcl_mjdg() (if (< (setq index (load_dialog "mjdg")) 0 ) (exit)) (if (not (new_dialog "mjdg" index )) (exit)) (set_tile "kd" "5") (set_tile "kl" "50") (set_tile "kl2" "20") (set_tile "rb2" "1") (set_tile "kimage1" "1") (cond ((= "kimage1" "1")(mode_tile "长度 L" 1)) ((= "kimage2" "1")(mode_tile "长度 L2" 0)(mode_tile "长度 L2" 4)) ) (start_image "kimage1") (setq x (dimx_tile "kimage1")) (setq y (dimy_tile "kimage1")) (fill_image 0 0 x y -2) (end_image) (setq x (dimx_tile "kimage1")) (setq y (dimy_tile "kimage1")) (start_image "kimage1") (slide_image 0 0 x y "Drawing1.sld") (end_image) (start_image "kimage2") (setq x (dimx_tile "kimage2")) (setq y (dimy_tile "kimage2")) (fill_image 0 0 x y -2) (end_image) (setq x (dimx_tile "kimage2")) (setq y (dimy_tile "kimage2")) (start_image "kimage2") (slide_image 0 0 x y "Drawing2.sld") (end_image) (start_list "kd") (setq dlst '("3" "4" "5" "6" "8" "10" "12")) (mapcar 'add_list dlst) (end_list) (action_tile "rb0" "(setq aa 0)") (action_tile "rb1" "(setq aa 1)") (action_tile "rb2" "(setq aa 2)") (action_tile "rb3" "(setq aa 3)") (action_tile "rb4" "(setq aa 4)") (action_tile "kmage1" "(setq ddtype 1)") (action_tile "kmage2" "(setq ddtype 2)") (action_tile "kd" "(setq d17 $value)") (start_dialog) (setq d17 (read d17)) (setq d17 (nth d17 dlst) d17 (read d17)) (if (= ddtype 1)((data1a)(fget1 d17 "data1"))((data2a)(fget1 d17 "data2"))) (action_tile "accept" "(setq d (atof (get_tile "kd")))(setq L (atof (get_tile "kl")))(setq L2 (atof (get_tile "kl2")))") (unload_dialog index) (cond ((and (= ddtype 1)(= aa 0))(tgtx1 1 0)) ; 执行不同型号零件和不同图号的绘图程序 ((and (= ddtype 1)(= aa 1))(tgtx1 1 1)) ((and (= ddtype 1)(= aa 2))(tgtx1 1 2)) ((and (= ddtype 1)(= aa 3))(tgtx1 1 3)) ((and (= ddtype 1)(= aa 4))(tgtx1 1 4)) ((and (= ddtype 2)(= aa 0))(tgtx1 2 0)) ((and (= ddtype 2)(= aa 1))(tgtx1 2 1)) ((and (= ddtype 2)(= aa 2))(tgtx1 2 2)) ((and (= ddtype 2)(= aa 3))(tgtx1 2 3)) ((and (= ddtype 2)(= aa 4))(tgtx1 2 4)) ) ) (defun tgtx1 (flag1 flage2) (command "color" "bylayer") (command "erase" "c" '(0 0) '(1200 1200) "") )
(defun data1a() ;数据库1 (setq data1 '((d11 d12 D D21 D22 D1 H) ((3(+0.010 0 6 -0.010 -0.022 10 4)) (4(+0.012 0 7 -0.013 -0.028 11 4)) (5(+0.012 0 8 -0.013 -0.028 13 4)) (6(+0.012 0 10 -0.013 -0.028 15 6)) (8(+0.015 0 12 -0.016 -0.034 17 6)) (10(+0.015 0 14 -0.016 -0.034 19 6)) (12(+0.018 0 17 -0.016 -0.034 22 6)) ))) ) (defun data2a() ;数据库2 (setq data2 '((d11 d12 D D21 D22 D1 D2 D3 H L1) ((3(+0.010 0 6 -0.010 -0.022 12 7 17 6 3)) (4(+0.012 0 7 -0.013 -0.028 14 9 19 6 4)) (5(+0.012 0 8 -0.013 -0.028 14 9 19 6 4)) (6(+0.012 0 10 -0.013 -0.028 14 9 19 6 4)) (8(+0.015 0 12 -0.016 -0.034 18 13 23 8 6)) (10(+0.015 0 14 -0.016 -0.034 20 15 25 8 6)) (12(+0.018 0 17 -0.016 -0.034 22 17 27 8 8)) ))) )
(defun fget1 (fa lname / lh lst j nn) ;数据库检索函数 (setq lh(car(eval(read lname))) lst(cadr(eval(read lname))) j -1) (setq lst (cadr (assoc fa lst))) (repeat(length lh) (setq j (1+ j) nn (nth j lh)) (set nn (nth j lst)) lst) )
