我的这个程序是渐开线齿轮,输入数据后会自动画,请问怎么改程序能不要演示这个自动画的动作,请帮帮我,万分感谢! 以下是程序,也可下载了看! (defun c:jkxcl() (setq os(getvar "osmode")) (setvar "osmode" 0) (setq m(getreal"输入模数:M=") z(getint"输入齿数:Z=") h(getreal"输入齿轮宽度:H=") zj(getreal"输入齿轮轴径:ZJ=") lf(getreal"输入轮辐厚度(无轮辐结构时输入齿轮宽度):LF=") ) (if (> h lf) (progn (setq gr(getreal"输入轮毂端面半径:gr=")) (setq yr(getreal"输入轮缘端面半径:yr=")) (setq s(/ (- h lf) 2)) (setq l(- h s)) ) ) (setq rf(/ (* (- z 2.5) m) 2) rj(/ (* m z 0.939693) 2) r (/ (* z m) 2) ra(/ (* (+ z 2) m) 2) tt(* m pi) pj(/ 36.0 z) a (/ (* 1.25 m) (cos (* 20 (/ pi 180)))) pt0(list 200.0 30.0 0.0) pt1(polar pt0 0 (/ tt 4)) pt2(polar pt0 pi (/ tt 4)) pt3(polar pt1 (* 110 (/ pi 180)) a) pt5(polar pt1 (* -70 (/ pi 180)) a) pt4(polar pt2 (* 70 (/ pi 180)) a) pt6(polar pt2 (* 250 (/ pi 180)) a) pt7(polar pt6 (* -90 (/ pi 180)) 2) ) (command "layer" "m" "11" "c" 1 "" "" "layer" "m" "12" "c" 2 "" "" "layer" "m" "13" "c" 252 "" "" "layer" "s" "13" "" "pline" pt7 pt6 pt4 pt3 pt5 ) (setq i 1) (while (<= i 7) (setq pt6(polar pt6 0 tt) pt4(polar pt4 0 tt) pt3(polar pt3 0 tt) pt5(polar pt5 0 tt) ) (command pt6 pt4 pt3 pt5) (setq i(+ i 1)) ) (setq pt8(polar pt5 (* -90 (/ pi 180)) 2)) (command pt8 "c") (setq pt(polar pt0 (* 180 (/ pi 180)) (* 4 tt))) (command "move" "l" "" pt0 pt) (setq e0(entlast)) (command "layer" "s" 11 "") (setq p0(polar pt0 (* 90 (/ pi 180)) r)) (command "circle" p0 ra) (command "region" "l" "") (setq e10 (entlast)) (command "layer" "s" "12" "") (setq j 1) (while (<= j z) (setq i 1) (while (<= i 10) (command "rotate" e10 "" p0 pj) (setq yd(* r pj (/ pi 180) i)) (setq pt(polar pt0 0 yd)) (command "copy" e0 "" pt0 pt) (command "region" "l" "") (setq e1(entlast)) (command "subtract" e10 "" e1 "") (setq i (+ i 1)) ) (setq j(+ j 1)) ) (command "layer" "s" "11" "") (command "extrude" e10 "" h 0) (setq e5 (entlast)) (command "erase" e0 "") (if (> h lf)(progn (command "circle" p0 yr) (setq e1(entlast)) (command "extrude" e1 "" s 5) (setq e1(entlast)) (command "circle" p0 gr) (setq e2(entlast)) (command "extrude" e2 "" s -5) (setq e2(entlast)) (command "subtract" e1 "" e2 "") (setq pt(list (car p0) (car (cdr p0)) h)) (setq s(- 0 s)) (command "circle" pt yr) (setq e3(entlast)) (command "extrude" e3 "" s 10) (setq e3(entlast)) (command "circle" pt gr) (setq e4(entlast)) (command "extrude" e4 "" s -10) (setq e4 (entlast)) (command "subtract" e3 "" e4 "") (command "cylinder" p0 (/ zj 2) h) (setq e4(entlast)) (command "subtract" e5 "" e1 e3 e4 "") ) (progn (command "cylinder" p0 (/ zj 2) h) (setq e4(entlast)) (command "subtract" e5 "" e4 "") ) ) (setvar "osmode" os) )
