查看: 899|回复: 1
用Recordset管理实体数据
发表于 2008-5-28 15:04:00 | 显示全部楼层 |阅读模式
  1. Sub gggg()
  2. Dim Ent As AcadEntity, tt As AcadText
  3.           Dim adoRecordset    As ADODB.Recordset
  4.           Set adoRecordset = New ADODB.Recordset
  5.           aa = Array("EntityText", "X", "Y", "Z"): bb = Array(adBSTR, adDouble, adDouble, adDouble)
  6.   With adoRecordset
  7.           For i = 0 To 3                '为Recordset2个字段,即为  DataGrid  添加2列
  8.             .Fields.Append aa(i), adVariant, , adFldMayBeNull
  9.             .Fields.Item(i).Type = bb(i)
  10.           Next i
  11.           .Open
  12.     For Each Ent In ThisDrawing.ModelSpace
  13.        Select Case Ent.ObjectName
  14.          Case "AcDbText"
  15.            Set tt = Ent
  16.              If tt.Layer = "零件表格文本" Then
  17.                .AddNew
  18.                .Fields(1).Value = Round(tt.InsertionPoint(0), 2)
  19.                .Fields(2) = Round(tt.InsertionPoint(1), 2)
  20.                .Fields(3) = 0
  21.                .Fields(0) = tt.TextString
  22.              End If
  23.         End Select
  24.      Next Ent
  25.      .Sort = y
  26.      .MoveFirst
  27.      For ii = 0 To .RecordCount - 1
  28.        Debug.Print .Fields(0).Value, .Fields(1).Value; .Fields(2).Value
  29.        .MoveNext
  30.      Next ii
  31.   End With
  32. End Sub
发表于 2008-5-30 09:11:00 | 显示全部楼层
赞一个
GMT+8, 2025-2-22 05:34 , Processed in 0.142530 second(s), 23 queries , Gzip On.
