查看: 1646|回复: 3
[求助]如何列印图形中所有非匿名块
发表于 2008-6-5 09:32:00 | 显示全部楼层 |阅读模式
用lsp改名时用的.
发表于 2008-6-5 09:47:00 | 显示全部楼层
  1. ;;;块列表,不含匿名块
  2. (defun GetBlockListxx (/ blist b)
  3.     (setq blist nil)
  4.     (if (tblnext "BLOCK" T)
  5.       (progn (setq blist (cons (cdr (assoc 2 (tblnext "BLOCK" T))) blist))
  6.       (while (setq b (tblNext "BLOCK"))
  7.         (setq blist (cons (cdr (assoc 2 b)) blist))
  8.       )
  9.       )
  10.     )
  11.     (vl-remove-if '(lambda (s) (= "*" (substr s 1 1))) blist)
  12.   )
 楼主| 发表于 2008-6-5 09:54:00 | 显示全部楼层
谢谢!
发表于 2012-4-1 11:31:40 | 显示全部楼层
这有类似的vla代码:
请问怎么列出当前DWG中的所有匿名块名称?
http://bbs.mjtd.com/forum.php?mo ... 3&fromuid=38464
GMT+8, 2025-9-25 05:14 , Processed in 0.147916 second(s), 25 queries , Gzip On.
