想编一小程序,实现从界面输入一数值,然后以此为坐标画线,程序如下:运行时textbox的数值传不过去,不知为什么? (command "OPENDCL") (defun c:qqq () ; call the method to load the Hello.odcl file. (dcl_Project_Load "qqq" T) ; call the method to show the Hello world dialog box example (dcl_Form_Show qqq_Form1) (princ) ) (defun c:qqq_Form1_TextBox2_OnEditChanged (sText /) ;(dcl_Control_SetText qqq_Form1_TextBox4 ; sText [as String]) (setq y1 sText)
(setq x1 (atoi y1)) (command "line" "0,0" "x1,x1" "") ) )
