查看: 1048|回复: 0
新手请教:为什么到最后一步的时候不能画面域
发表于 2008-6-13 16:21:00 | 显示全部楼层 |阅读模式
Sub mianyu()
Dim p1 As Variant '端点坐标
Dim p2 As Variant
Dim l() As Double
Dim temp(1 To 2) As AcadPolyline
p1 = ThisDrawing.Utility.GetPoint(, "输入点:")
z = 0
p1(2) = z
ReDim l(0 To 2)
l(0) = p1(0)
l(1) = p1(1)
l(2) = z
On Error GoTo Err_Control
Do
  p2 = ThisDrawing.Utility.GetPoint(p1, vbCr & "输入下一点:")
  z = 0
  p2(2) = z
  lub = UBound(l)
  ReDim Preserve l(lub + 3)
  For i = 1 To 3
    l(lub + i) = p2(i - 1)
  Next i
  If lub > 3 Then
    templ.Delete
  End If
  Set templ = ThisDrawing.ModelSpace.AddPolyline(l)
  p1 = p2
Loop
Err_Control:
Set temp2 = ThisDrawing.ModelSpace.AddPolyline(l)
Dim regions As Variant
regions = ThisDrawing.ModelSpace.AddRegion(temp)
End Sub
GMT+8, 2025-2-22 02:22 , Processed in 0.178040 second(s), 23 queries , Gzip On.
