查看: 1143|回复: 1
想连续标注,该怎么实现呢?急
发表于 2008-6-14 23:15:00 | 显示全部楼层 |阅读模式
参考别人的写了一段标注面积的程序,现在想连续标注多个封闭区域面积,并且按“Esc”键时退出,该怎么实现呢?
本人新手,恳求大侠不吝赐教!谢谢
  1. Sub get_area()
  2.     On Error Resume Next
  3.     Dim n As Long
  4.     n = ThisDrawing.ModelSpace.Count
  5.
  6.     Dim pt As Variant
  7.     Dim txet_ht As Double, gch As Double
  8.     pt = ThisDrawing.Utility.GetPoint(, "请指定区域内部点: ")
  9.     ThisDrawing.SendCommand "_-Boundary" & vbCr & pt(0) & "," & pt(1) & vbCr & vbCr
  10.     Dim lwpLineObj As AcadLWPolyline
  11.     Dim textObj As AcadMText
  12.     Dim area As Double
  13.
  14.     If ThisDrawing.ModelSpace.Count > n Then
  15.
  16.         Set lwpLineObj = ThisDrawing.ModelSpace.Item(ThisDrawing.ModelSpace.Count - 1)
  17.         lwpLineObj.color = acRed
  18.         txet_ht = 15
  19.         txet_ht = ThisDrawing.Utility.GetReal("请输入文字高度<15.0>: ")
  20.         gch = ThisDrawing.Utility.GetReal("请输入区域高程<" & gch & ">:")
  21.         area = Round(lwpLineObj.area, 2)
  22.         Set textObj = ThisDrawing.ModelSpace.AddMText(pt, 30 * txet_ht, "高程:" & gch & "\P" & "面积:" & area)
  23.         textObj.Height = txet_ht
  24.         textObj.Update
  25.         If Err Then
  26.             Err.Clear
  27.             Exit Sub
  28.         End If
  29.      Else
  30.          MsgBox "未发现封闭区域,请检查选定区域是否闭合. "
  31.
  32.     End If
  33. End Sub
发表于 2008-6-16 09:43:00 | 显示全部楼层
LZ请联系我,QQ45096732
GMT+8, 2025-5-1 09:58 , Processed in 0.156498 second(s), 24 queries , Gzip On.
