简单改了一下,应该满足要求了 (defun c:rt () (setq datfile (getfiled "展点原始数据:" "F:\\11" "txt" 2)) ;查找文件路径 (setq ff (open datfile "r")) (setq dat T) (setq dat (read-line ff)) (while dat (setq data (read (strcat "(" dat ")"))) (setq ptr (cons data ptr)) (setq dat (read-line ff)) ) (setq b 4) )
