查看: 1116|回复: 0
[原创]实体数据存到txt文件一例。
发表于 2008-6-21 12:48:00 | 显示全部楼层 |阅读模式
现在多数人是将实体数据存到mdb或xls中。
mdb 文件太大,字段需要定义。xls文件受到65535行的限制。txt文件比较少。下面一例就是将实体数据存到 txt中。
  1. Sub ll()
  2.   Dim LineData As AcadLine, ArcData As AcadArc
  3.   Close #1
  4.   Open "D:\ls.txt" For Output As #1
  5.
  6.   Write #1, "m1", "m2", "m3", "m4", "m5", "m6", "m7", "m8", "m9", "m10", "m11", "m12"
  7.
  8.   Dim Ent As AcadEntity
  9.
  10.   For Each Ent In ThisDrawing.ModelSpace
  11.     m1 = Ent.ObjectName
  12.     m2 = Ent.ObjectID
  13.     Select Case Ent.ObjectName
  14.       Case "AcDbLine"
  15.         Set LineData = Ent
  16.         With LineData
  17.           m3 = Round(.StartPoint(0), 5)
  18.           m4 = Round(.StartPoint(1), 5)
  19.           m5 = Round(.StartPoint(2), 5)
  20.           m6 = Round(.EndPoint(0), 5)
  21.           m7 = Round(.EndPoint(1), 5)
  22.           m8 = Round(.EndPoint(2), 5)
  23.
  24.         End With
  25.     End Select
  26.     Write #1, m1, m2, m3, m4, m6, m7, m8
  27.
  28.   Next Ent
  29.   Ent.GetBoundingBox
  30.   Close #1
  31. End Sub
AutoCAD的VBA中照样可以用SQL语句,相当方便。
GMT+8, 2025-5-1 09:36 , Processed in 0.166164 second(s), 23 queries , Gzip On.
