查看: 3368|回复: 5
如何用VB6实现自动拾取计算CAD图形中线的长度
发表于 2008-6-21 15:53:00 | 显示全部楼层 |阅读模式
如何用VB6编程实现自动拾取计算CAD图形中线的长度,并将其值返回列表框?
 楼主| 发表于 2008-6-21 17:52:00 | 显示全部楼层
望哪位高手能不吝赐教,给编个源码,说明一下
发表于 2008-6-22 12:42:00 | 显示全部楼层
你先在VBA中理解清楚
dim ll as acadline
debug.pring ll.length 就是你要的线段长度。
转到VB6.0很简单,关键是你有没有这方面的基础。在这里找一下有实例。
 楼主| 发表于 2008-6-23 01:56:00 | 显示全部楼层
VBA中是否要导入vlax.cls类?怎样实施,如果采用VB6又如何实施呢?我是一个新手,劳烦版主能举例讲详细一点好吗?再次谢谢!!!!!!!
 楼主| 发表于 2008-6-29 12:25:00 | 显示全部楼层
哪位高手能给个VB6的实例吗,给个有源码实例的链接也行
 楼主| 发表于 2008-7-3 01:17:00 | 显示全部楼层
能否将以下的VBA拾取计算CAD线段长度代码,转换成VB6代码?望哪位指点.在此感谢!!!
'Private Declare Function GetCursorPos Lib "user32" (lpPoint As POINTAPI) As Long
Private Type POINTAPI
x As Long
Y As Long
End Type
Public Function CreateSelectionSet(Optional ssName As String = "SS3") As AcadSelectionSet
  '返回一个空白选择集
   Dim SS3 As AcadSelectionSet
    On Error Resume Next
    Set SS3 = ThisDrawing.SelectionSets(ssName)
    If Err Then Set SS3 = ThisDrawing.SelectionSets.Add(ssName)
    SS3.Clear
    Set CreateSelectionSet = SS3
End Function
Function Long_OverFlow_To_Double(ByVal longVal As Long) As Double
   '将大于2147483647的数值longVal 转换为double类型
    Dim ret_val As Double
    Dim over_long As Double  '2的32次方
    'N(真值)=4294967296#(2的32次方)-[N(真值)]补码
    over_long = 4294967296#
    If longVal < 0 Then
        ret_val = over_long + (longVal)
    End If
Long_OverFlow_To_Double = ret_val
End Function
Public Function Round(ByVal nValue, Optional nPlaces As Integer = 2) As Double
Dim tmp As Integer
nValue = CDbl(nValue)
tmp = Fix(nValue)
nValue = CInt((nValue - tmp) * 10 ^ nPlaces)
Round = tmp + nValue / 10 ^ nPlaces
End Function
Public Function Roundl(ByVal nValue, Optional nPlaces As Integer = 2) As Double
Dim tmp As Long
tmp = Fix(nValue)
Roundl = tmp + nValue / 10 ^ nPlaces
End Function
Public Function Roundd(ByVal nValue, Optional nPlaces As Integer = 2) As Double
Dim tmp As Double
tmp = Fix(nValue)
Roundd = tmp + nValue / 10 ^ nPlaces
End Function
Function Distance(Point1, Point2) As Double
    Dim dist As Double
    For i = LBound(Point1) To UBound(Point1)
        dist = dist + ((Point1(i) - Point2(i)) ^ 2)
        If Err Then Exit For
    Next
    Distance = Sqr(dist)
End Function
Function existtext(plineObj As Object) As Boolean
       Dim textObj As AcadText
      Dim ent As Object
       Dim DataType(0 To 1) As Integer
       Dim Data(0 To 1) As Variant
       Dim ss As AcadSelectionSet
       Dim FilterType(0) As Integer
       Dim FilterData(0) As Variant
       FilterType(0) = 0
       FilterData(0) = "text"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = FilterType
    dataCode = FilterData
      ThisDrawing.SelectionSets("Test").Delete
    Set ss = ThisDrawing.SelectionSets.Add("Test")
    Dim InsertionPoint(0 To 2) As Double
   InsertionPoint(0) = plineObj.Coordinate(0)(0): InsertionPoint(1) = plineObj.Coordinate(0)(1): InsertionPoint(2) = 0
    Dim corner1(0 To 2) As Double
    Dim corner2(0 To 2) As Double
    corner1(0) = plineObj.Coordinate(0)(0) - 20: corner1(1) = plineObj.Coordinate(0)(1) - 20: corner1(2) = 0
    corner2(0) = plineObj.Coordinate(0)(0) + 20: corner2(1) = plineObj.Coordinate(0)(1) + 20: corner2(2) = 0
      ss.Select acSelectionSetCrossing, corner1, corner2, groupCode, dataCode
        If ss.Count = 0 Then
              DataType(0) = 1001: Data(0) = "MRApplication"
                 DataType(1) = 1000: Data(1) = "qd"
              Set textObj = ThisDrawing.ModelSpace.AddText("起点", InsertionPoint, 500)
              textObj.SetXData DataType, Data
       End If
     If ss.Count > 0 Then
     For Each ent In ss
               If ent.TextString = "起点" Then
               Else
               End If
         Next
    End If
End Function
Function Drawcircle(intpoints As Variant)
      Dim circleObj As AcadCircle
       FilterType(0) = 0
       FilterData(0) = "Circle"
      ThisDrawing.SelectionSets("cir").Delete
    Set ss = ThisDrawing.SelectionSets.Add("cir")
    corner1(0) = intpoints(0) - 6: corner1(1) = intpoints(1) - 6: corner1(2) = 0
    corner2(0) = intpoints(0) + 6: corner2(1) = intpoints(1) + 6: corner2(2) = 0
     Set circleObj = ThisDrawing.ModelSpace.AddCircle(intpoints, 5)
     DataType(1) = 1000: Data(1) = "cir"
     circleObj.SetXData DataType, Data  '
      End If
End Function
Function qj(ent As AcadEntity, removeObjects() As AcadEntity, numbera) As Double
  Dim intpoints As Variant
  Dim d1, d2, d3 As Double
  Dim qjx As Double
  qjx = 0
           For m = 0 To numbera
           intpoints = ent.IntersectWith(removeObjects(m), acExtendNone)
           If UBound(intpoints) > -1 Then Exit For
           Next
                   For jds = (UBound(removeObjects(m).Coordinates) + 1) / 2 - 1 To 1 Step -1
                        d3 = Roundd(Distance(removeObjects(m).Coordinate(jds), removeObjects(m).Coordinate(jds - 1)), 2)
                        d2 = Roundd(Distance(removeObjects(m).Coordinate(jds), intpoints), 2)
                        d1 = Roundd(Distance(removeObjects(m).Coordinate(jds - 1), intpoints), 2)
                            If d1 + d2 - 0.03 < d3 And d3 < d1 + d2 + 0.03 Then
                                  If jds > 1 Then
                                   For n = jds - 1 To 1 Step -1
                                  qjx = Distance(removeObjects(m).Coordinate(n), removeObjects(m).Coordinate(n - 1)) + qjx
                                  Next
                                  End If
                                qjx = d1 + qjx
                                Drawcircle intpoints
                                Exit For
                            End If
                  Next
              End If
   qj = qjx
  End Function
Function ybg(sset As AcadSelectionSet) As Boolean
     Dim ent As AcadEntity
     Dim PStartpoint, PEndpoint As Variant
       For Each ent In sset
       If ent.ObjectName = "AcDbLine" Then
       PStartpoint = ent.StartPoint
       PStartpoint(2) = 0
       ent.StartPoint = PStartpoint
       PEndpoint = ent.EndPoint
       PEndpoint(2) = 0
       ent.EndPoint = PEndpoint
       ent.Update
       End If
    If ent.ObjectName = "AcDbPolyline" Then
       ent.Elevation = 0
        ent.Update
        End If
    Next
End Function
Private Sub CommandButton1_Click()
Dim sset As AcadSelectionSet
Set sset = CreateSelectionSet("SS3")
 Dim xdataOut As Variant
 Dim xtypeOut As Variant
 ListBox1.Clear
              FilterType(0) = 0
              FilterData(0) = "LWPolyline"
              sset.SelectOnScreen FilterType, FilterData
              Dim ent As Object
                ent.GetXData "", xtypeOut, xdataOut
                If VarType(xdataOut) = 8204 Then
                  If xdataOut(1) = "MR" Then
                  existtext ent
                  ListBox1.AddItem "坐标 X= " & Roundd(ent.Coordinate(0)(0), 0) & " Y= " & Roundd(ent.Coordinate(0)(1), 0)
                  End If
                End If
              Next
     ThisDrawing.SelectionSets.Item("SS3").Delete
End Sub
Private Sub CommandButton2_Click()
If Me.CommandButton2.Caption = "设定MR" Then
UserForm1.CommandButton4.Enabled = False
Me.CommandButton2.Caption = "隐藏"
UserForm1.Width = 210
UserForm1.Height = 145
Else
UserForm1.CommandButton4.Enabled = True
UserForm1.Width = 90
UserForm1.Height = 130
End If
End Sub
Private Sub CommandButton3_Click()
  ThisDrawing.SelectionSets("SS2").Delete
  Set sset = ThisDrawing.SelectionSets.Add("SS2")
    FilterType(0) = 0
    FilterData(0) = "LWPolyline,line"
    Dim ent As Object
      Dim plineObj As AcadLWPolyline
        Dim PStartpoint As Variant
        Dim PEndpoint As Variant
        Dim newVertex(0 To 3) As Double
        newVertex(0) = PStartpoint(0): newVertex(1) = PStartpoint(1)
        newVertex(2) = PEndpoint(0): newVertex(3) = PEndpoint(1)
        Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(newVertex)
      ent.Delete
      Else
      Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(ent.Coordinates)
      ent.Delete
      End If
     DataType(1) = 1000: Data(1) = "MR"
     plineObj.SetXData DataType, Data  ' 在直线上附着扩展数据
     Dim color As AcadAcCmColor
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor.16")
    Call color.SetRGB(254, 0, 0)
    plineObj.TrueColor = color
       existtext plineObj
       Next
ThisDrawing.SelectionSets.Item("SS2").Delete
'retCoord = plineObj.Coordinates
'For Number = LBound(retCoord) To UBound(retCoord)
'a = a & retCoord(Number) & Chr(13)
'Next
End Sub
Private Sub CommandButton4_Click()
Static bRun As Boolean
bRun = Not bRun
If bRun Then
'CommandButton4.Caption = "停止计算"
'UserForm1.CommandButton2.Enabled = False
      'While bRun
           If UserForm1.ComboBox1.ListIndex = 0 Then Call qzx
           'If UserForm1.ComboBox1.ListIndex = 1 Then Call qd
          DoEvents
     ' Wend
 Else
 CommandButton4.Caption = "开始计算"
 UserForm1.CommandButton2.Enabled = True
 Exit Sub
End If
End Sub
Private Sub CommandButton5_Click()
                  ThisDrawing.SelectionSets("SS4").Delete
                  Set sset = ThisDrawing.SelectionSets.Add("SS4")
                    FilterType(0) = 0
                   Dim ent As Object
                If VarType(xdataOut) = 8204 Then ent.Delete
                Next
  ThisDrawing.SelectionSets.Item("SS4").Delete
End Sub
Private Sub CommandButton6_Click()
                ThisDrawing.SelectionSets("SS111").Delete
                  Set sset = ThisDrawing.SelectionSets.Add("SS111")
                    FilterType(0) = 0
                    FilterData(0) = "circle"
                    sset.Highlight True
                   Dim ent As Object
                Next
  ThisDrawing.SelectionSets.Item("SS111").Delete
End Sub
Private Sub CommandButton7_Click()
Dim a, m, n As Integer
a = 0
Dim temp() As Double
Set sset = CreateSelectionSet("SS22")
              FilterType(0) = 0
              Dim ent As Object
                  a = 1
                  n = (UBound(ent.Coordinates) + 1) / 2 - 1
               '   Dim tempobj As Variant
              '  Dim objCollection(0 To 0) As Object
               '  Set objCollection(0) = ent
               '   tempobj = ThisDrawing.CopyObjects(objCollection)
                    Dim tempobj As AcadLWPolyline
                     Set tempobj = ent.Copy()
                    For m = 0 To n
                    ent.Coordinate(m) = tempobj.Coordinate(n - m)
                    Next
                   tempobj.Delete
                  existtext ent
                  End If
                End If
              Next
     ThisDrawing.SelectionSets.Item("SS22").Delete
If a = 0 Then MsgBox "找不到桥架"
End Sub
Private Sub ListBox1_DblClick(ByVal Cancel As MSForms.ReturnBoolean)
   Dim zcenter(0 To 2) As Double
    Dim magnification As Double
    zcenter(0) = Split(ListBox1.List(ListBox1.ListIndex), " ")(2)
    zcenter(1) = Split(ListBox1.List(ListBox1.ListIndex), " ")(4): zcenter(2) = 0
    magnification = ThisDrawing.GetVariable("VIEWSIZE")
    ZoomCenter zcenter, magnification
      Dim ent As Object
       FilterType(0) = 0
    corner1(0) = zcenter(0) - 30: corner1(1) = zcenter(1) - 30: corner1(2) = 0
    corner2(0) = zcenter(0) + 30: corner2(1) = zcenter(1) + 30: corner2(2) = 0
              Set textObj = ThisDrawing.ModelSpace.AddText("起点", zcenter, 500)
       End If
     For Each ent In ss
               Else
               End If
         Next
    End If
End Sub
Private Sub UserForm_Initialize()
ComboBox1.AddItem "取直线"
ComboBox1.AddItem "取点"
End Sub
Private Sub UserForm_QueryClose(Cancel As Integer, CloseMode As Integer)
ThisDrawing.SelectionSets.Item("SS1").Delete
ThisDrawing.SendCommand Chr(3) & Chr(3) & Chr(3) & vbCrLf & Chr(3)
End Sub
Sub qzx()
         ThisDrawing.Utility.Prompt (vbCrLf & "取直线计算")
         ThisDrawing.SelectionSets("SS1").Delete
         Set sset = ThisDrawing.SelectionSets.Add("SS1")
             FilterType(0) = 0
             If UserForm1.Visible = False Then Exit Sub
             Call ybg(sset)
              Dim removeObjects(0 To 30) As AcadEntity
                    Dim numbera, jds, js1, js2 As Integer: Dim qjx, gz, temp As Double
                    numbera = 0: jds = 0
                    gz = 0: qjx = 0: js1 = 0: js2 = 0
                      Set removeObjects(numbera) = ent
                      numbera = numbera + 1
                      End If
                    Next
              If numbera > 0 Then
              sset.RemoveItems removeObjects
              End If
              If numbera = 0 Then
                    gz = ent.Length + gz
                    js1 = js1 + 1
                 Next
                End If
              If numbera > 0 Then
                    qjx = qj(ent, removeObjects, numbera - 1) + qjx
                    If temp <> qjx Then js2 = js2 + 1
                    temp = qjx
                  js1 = js1 + 1
                  Next
              End If
        gz = Round(gz / 1000, 2)
        qjx = Round(qjx / 1000, 2)
        MsgBox js1 & "对象穿管长度:" & gz & "米" & Chr(13) & js2 & "对象穿桥架长:" & qjx & "米"
End Sub
Sub qd()
       On Error GoTo Err_Control
       ThisDrawing.Utility.Prompt (vbCrLf & "取点计算")
       Dim lineObj(20) As AcadLine
       Dim strArr(20) As Variant
        Dim p1, p2 As Variant
     Dim m As Double
         Dim k, j As Integer
           k = 1
             strArr(0) = ThisDrawing.Utility.GetPoint(, "获取第" & k & "点")
          ThisDrawing.Utility.Prompt (vbCrLf & "第" & k & "点" & "x=" & strArr(0)(0) & " y=" & strArr(0)(1) & vbCrLf)
          For j = 1 To 20
                k = k + 1
             strArr(j) = ThisDrawing.Utility.GetPoint(strArr(j - 1), "获取第" & k & "点")
              ThisDrawing.Utility.Prompt (vbCrLf & "第" & k & "点" & "x=" & strArr(j)(0) & " y=" & strArr(j)(1) & vbCrLf)
           Set lineObj(j - 1) = ThisDrawing.ModelSpace.AddLine(strArr(j - 1), strArr(j))
          Next
Err_Control:
                    Select Case Err.Number
                         Case -2145320928#
                       ThisDrawing.Utility.Prompt (vbCrLf & "共获取" & k - 1 & "点")
                        For j = 0 To k - 1
                         p1 = strArr(j)
                         p2 = strArr(j + 1)
                         m = m + Distance(p1, p2)
                        Next
                        m = Round(m / 1000, 2)
                     If UserForm1.Visible = False Then GoTo del
                        MsgBox k - 1 & "个点距离之:" & m & "米"
                        For j = 0 To k - 3
                        lineObj(j).Delete
                        Next
                     Case -2147352567#
del:                          For j = 0 To k - 3
                               lineObj(j).Delete
                            Next
                    'ThisDrawing.SendCommand Chr(3) & Chr(3)
                       Case Else
                      '     MsgBox Err.Number & Err.Description
                       End Select
End Sub
望各位高手不吝赐教,谢谢!!!!!
GMT+8, 2025-2-21 03:09 , Processed in 0.196649 second(s), 24 queries , Gzip On.
