查看: 1955|回复: 0
[求助][讨论]vla-addmtext函数是否可以控制对正方式和文字高度?
发表于 2008-6-28 15:47:00 | 显示全部楼层 |阅读模式
(setq mspace (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-acad-object))))
(vla-addmtext mspace (vlax-3d-point insert_pt) 0 "新建MTEXT文本")
(command "mtext" insert_pt "j" "mc" "h" 5 insert_pt "新建MTEXT文本" "")
我想用前面两句代替最后一句。问题是,用vla-addmtext 时对正方式和文本高度应该怎么设置?
GMT+8, 2025-5-1 07:50 , Processed in 0.369174 second(s), 25 queries , Gzip On.
