查看: 4512|回复: 5
[求助]CAD中坐标值批量转移到EXCEL中
发表于 2008-7-1 10:37:00 | 显示全部楼层 |阅读模式
我想把CAD中光标所点的坐标值批量转移到EXCEL表格中。
例如:我打开一张CAD图形,上面有好多圆,我每点击一下(仅扑捉点击圆心),就会在EXCEL表格中按顺序把我点击的坐标数值显示出来
点号         X            Y
1           3000       2000
2           1000       2000
3           4000       3000
请高手帮我解决这个问题,谢谢!(能不能用一个lisp程序,把cad指定点坐标导出到EXCEL)?
发表于 2008-7-1 11:14:00 | 显示全部楼层
可以
可以帮到你的忙的,我的联系方式是QQ375564896
发表于 2008-7-8 08:08:00 | 显示全部楼层
你可以先创建一个记事本。先把坐标导入记事本在导入excel
Dim us3 As Integer '左下角Y坐标
us1 = ThisDrawing.GetVariable("userr1")
us2 = ThisDrawing.GetVariable("userr2")
us3 = ThisDrawing.GetVariable("userr3")
'Dim pnt_cord(0 To 1) As Double
Dim sset As AcadSelectionSet
Dim i As Integer
For i = 0 To ThisDrawing.SelectionSets.Count - 1
ThisDrawing.SelectionSets.Item(i).Clear
ThisDrawing.SelectionSets.Item(i).Delete
Next
ft(0) = 0
fd(0) = "Point"
Set sset = ThisDrawing.SelectionSets.Add("Sset_P")
sset.Select acSelectionSetAll, , , ft, fd
ReDim pnt_cord(sset.Count - 1) As Variant
ReDim x(sset.Count - 1)
ReDim y(sset.Count - 1)
dnr = ""
For i = 0 To sset.Count - 1
pnt_cord(i) = sset.Item(i).Coordinates
Select Case us1
Case 500
If us2 = 0 And us3 = 0 Then
x(i) = (pnt_cord(i)(1) - 100) / 2
y(i) = (pnt_cord(i)(0) - 100) / 2
ElseIf us2 = 100 And us3 = 100 Then
x(i) = (pnt_cord(i)(1) + 100) / 2
y(i) = (pnt_cord(i)(0) + 100) / 2
End If
Case 1000
x(i) = pnt_cord(i)(1) - 100
y(i) = pnt_cord(i)(0) - 100
End If
End Select
'*******按scs2000展点文件格式排列点
dnr = dnr & vbCrLf & (i + 1) & vbCrLf & "" & vbCrLf & y(i) & vbCrLf & x(i) & vbCrLf & pnt_cord(i)(2)
Next
outtxt = sset.Count & dnr
MsgBox "点导出成功,请保存文件!"
End Sub
发表于 2009-4-16 23:49:00 | 显示全部楼层
谢谢共享!
发表于 2010-2-22 17:48:00 | 显示全部楼层
是个好东西,不知是否可行啊。
发表于 2010-2-24 19:31:00 | 显示全部楼层
GMT+8, 2025-5-25 12:43 , Processed in 0.156109 second(s), 24 queries , Gzip On.
