查看: 2658|回复: 2
请教 AutoCAD 变量设置被拒绝: "bilpmode" 0
发表于 2008-7-1 15:55:00 | 显示全部楼层 |阅读模式
下面的代码运行时出现错误提示:
 错误: AutoCAD 变量设置被拒绝: "bilpmode" 0
如果把 (setvar "bilpmode" 0)注释上
运行以后出现 错误: AutoCAD 变量设置被拒绝: "blipmode" nil
请问是怎么回事?
(defun c:a4( / v1 v2 v3 ljmch cl shl bl)
   (setq v1(getvar "osmode"))
   (setq v2(getvar  "cmdecho"))
   (setq v3(getvar "bilpmode"))
   (setvar "osmode" 0)
   (setvar "cmdecho" 0)
  (setq ljmch(getstring "\n输入零件名称:"))
  (setq cl(getstring "\n输入零件材料:"))
  (setq shl (getint "\n输入零件数量:"))
  (setq shl(itoa shl))
  (setq bl(getstring "\n输入绘图比例"))
  (command "style" "hz" "宋体" "" "" "" "" "" "" "")
  (command "layer" "m" "xixian" "c" "1" "" "" ) ;设置图纸边框线
;;;  (command "color" 5)
  (command "limits" "0,0" "210,297")
  (command "zoom" "a")
  (command "line" "0,0" "210,0" "210,297" "0,297" "c")
  (command "layer" "m" "cuxian" "c" "7" "" "lw" 0.6 "" "");设置图框
  (command "line" "25,5" "205,5" "205,292" "25,292" "c")
  (command "line" "85,5" "85,27" "205,27" "")
  (command "line" "85,13" "205,13" "")
  (command "line" "100,13" "100,27" "")
  (command "line" "120,13" "120,27" "")
  (command "line" "132,5" "132,27" "")
  (command "line" "162,5" "162,13" "")
  (command "line" "180,5" "180,27" "")
  (command "layer" "m" "xixian" "")
  (command "line" "85,20" "132,20" "")
  (command "layer" "m" "wenzi" "c" "5" "" "")
  (command "text" "m" (list 188.5 9) 5 0 "清华大学机械厂")
  (command "text" "m" (list 147 9) 5 0 (strcat"材料" cl))
   (command "text" "m" (list 171 9) 5 0 (strcat"数量" shl))
   (command "text" "m" (list 192.5 9) 5 0 (strcat"比例" bl))
    (command "text" "m" (list 92.5 23.5) 5 0 "制图")
    (command "text" "m" (list 92.5 16.5) 5 0 "校核")
    (command "text" "m" (list 156 20) 10 0 ljmch)
  (setvar "osmode" v1)
  (setvar "cmdecho" v2)
  (setvar "blipmode" v3)
发表于 2008-7-1 16:09:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-7-1 21:20:00 | 显示全部楼层
各位老大,是写错了吧,应该是blipmode,而不是bilpmode
GMT+8, 2025-9-21 04:17 , Processed in 0.162355 second(s), 25 queries , Gzip On.
