查看: 1126|回复: 0
[求助]如果解决VB用二次开发的版本问题?
发表于 2008-7-9 22:14:00 | 显示全部楼层 |阅读模式
Dim acadApp As AcadApplication
Dim acadDoc As AcadDocument
Sub ConnectToAcad()
On Error Resume Next
  Set acadApp = GetObject(, "AutoCAD.Application")
  If Err Then
    Err.Clear
    Set acadApp = CreateObject("AutoCAD.Application")
    acadApp.Visible = True
    If Err Then MsgBox Err.Description
  End If
  Set acadDoc = acadApp.ActiveDocument
End Sub
Private Sub Command1_Click()
Dim start1(2) As Double
Dim end1(2) As Double
end1(0) = 100
Dim line As AcadLine
Call ConnectToAcad
Set line = acadDoc.ModelSpace.AddLine(start1, end1)
End Sub
上面的这样代码是没有问题可运行的,但版本只能限于我所在的版本(如2004版)
有朋友说
改为
Dim acadApp As Object
Dim acadDoc As Object
问题是我一这样用就出错,为什么呢?
GMT+8, 2025-5-1 10:54 , Processed in 0.148675 second(s), 24 queries , Gzip On.
