查看: 1234|回复: 0
[原创][分享]创建出同dli命令创建的一样的标注
发表于 2008-7-17 00:10:00 | 显示全部楼层 |阅读模式
  1. Sub AddDimRotated()
  2.     Dim dimObj As AcadDimRotated
  3.     Dim point1 As Variant
  4.     Dim point2 As Variant
  5.     Dim location As Variant
  6.     Dim rotAngle As Double
  7.     Dim rotAngleNunmer As Integer
  8.
  9.     rotAngleNunmer = 1
  10.
  11.     With ThisDrawing.Utility
  12.         point1 = (.GetPoint(, "请指定标注起始点(按Esc或Enter或左健退出):"))
  13.         If IsEmpty(point1) Then Exit Sub
  14.     End With
  15.
  16.     With ThisDrawing.Utility
  17.         point2 = (.GetPoint(, "请指定标注结束点(按Esc或Enter或左健退出):"))
  18.         If IsEmpty(point2) Then Exit Sub
  19.     End With
  20.
  21.     With ThisDrawing.Utility
  22.         location = (.GetPoint(, "请指定标注基准点(按Esc或Enter或左健退出):"))
  23.         If IsEmpty(location) Then Exit Sub
  24.     End With
  25.
  26.     On Error Resume Next
  27.     rotAngleNunmer = ThisDrawing.Utility.GetInteger(vbCrLf & "输入标注位置 [上(1)/下(2)/左(3)/右(4)]: <" & rotAngleNunmer & ">:")
  28.
  29.     Select Case rotAngleNunmer
  30.         Case 1, 2
  31.             rotAngle = 0
  32.         Case 3, 4
  33.             rotAngle = 90
  34.     End Select
  35.
  36.     rotAngle = rotAngle * 3.141592 / 180#       ' covert to Radians
  37.
  38.     Set dimObj = ThisDrawing.ModelSpace.AddDimRotated(point1, point2, location, rotAngle)
  39. End Sub
GMT+8, 2025-5-1 09:30 , Processed in 0.152678 second(s), 23 queries , Gzip On.
