查看: 1420|回复: 1
[求助]改造源码成配纵筋的程序
发表于 2008-7-17 18:51:00 | 显示全部楼层 |阅读模式
(defun c:test (/ ss)
  (princ (strcat "\n*** 将配筋率大于2%的字符显红V070528 ***"))
  (princ (strcat "\n        [它山之石图形工作室]"))
  (IF (setq ss (ssget '((0 . "*TEXT") (1 . "#*-#*-*#"))))
      (GL-SSMAP
 '(lambda (e / str)
    (setq e   (vlax-ename->vla-object e)
   str (vla-get-textstring e)
   str (GL-StrParse str "-")
   str (apply 'max (mapcar 'atoi str))
    (if (<= 0.2 str)
      (vla-put-color e 1)
    ) ;_ 结束if
  ) ;_ 结束lambda
 ss
      ) ;_ 结束mapcar
    ) ;_ 结束progn
  ) ;_ 结束IF
  (princ (strcat "\n《同是土木人》系列群之群⑥原创作品"
   "\n*******   群号:30845285   *******"
  ) ;_ 结束strcat
  ) ;_ 结束princ
) ;_ 结束defun
(defun GL-SSMAP (func ss / n)
  (if (eq 'pickset (type ss))
    (repeat (setq n (fix (sslength ss)))
      (apply func (list (ssname ss (setq n (1- n)))))
    ) ;_ 结束repeat
  ) ;_ 结束if
) ;_ 结束defun
(defun GL-StrParse
     (Str        Delimiter  /      SearchStr
      StringLen  return   n      char
      DelimiterLen
  (setq SearchStr Str)
  (setq StringLen (strlen SearchStr))
  (setq DelimiterLen (strlen Delimiter))
  (setq return '())
  (while (> StringLen 0)
    (setq n 1)
    (setq char (substr SearchStr 1 DelimiterLen))
    (while (and (/= char Delimiter) (/= char ""))
      (setq n (1+ n))
      (setq char (substr SearchStr n DelimiterLen))
    ) ;_ 结束while
    (setq return (cons (substr SearchStr 1 (1- n)) return))
    (setq SearchStr (substr SearchStr (+ DelimiterLen n) StringLen))
  ) ;_ 结束while
  (reverse return)
) ;_ 结束defun
(GL-StrParse "7-9-10" "-")
==>("7" "9" "10")
这是他山的作品,请改造成点取“8-9-8”求出最大值9,然后配出钢筋3根20的钢筋。
 楼主| 发表于 2008-7-18 13:34:00 | 显示全部楼层
怎么没有回帖啊,是不是太难了
GMT+8, 2025-9-21 04:17 , Processed in 0.155028 second(s), 25 queries , Gzip On.
