查看: 1774|回复: 2
[求助]各位 帮我看看 程序那的错呀??
发表于 2003-5-21 16:19:00 | 显示全部楼层 |阅读模式
(defun c:bg ()
  (setvar "cmdecho" 0)
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq pt1 (getpoint "\n第一点:"))
  (setq pt3 (getcorner pt1 "\n另一点:"))
  (command "rectang" "w" 1 pt1 pt3)
  (setq wnn (1+ (getint "\n列数 <5>:")))
  (if (null wnn)
    (setq wnn 5)
  (setq hnn (1+ (getint "\n行数 <5>:")))
  (if (null hnn)
    (setq hnn 5)
  (setq pt2 (list (car pt3) (cadr pt1)))
  (setq pt4 (list (car t1) (cadr pt3)))
  (setq ang (angle pt1 pt3))
  (cond        (and (> ang 0) (< ang (/ pi 2)))
        (setq pp1 pt1 pp2 pt2 pp3 pt3 pp4 pt4)
  ((and (> ang (/ pi 2)) (< ang pi))
    (setq pp1 pt2
          pp2 pt1
          pp3 pt4
          pp4 pt3
  ((and (> ang pi) (< ang (* pi 1.5)))
    (setq pp1 pt3
          pp2 pt4
          pp3 pt1
          pp4 pt2
  ((and (> ang (* pi 1.5)) (< ang (* pi 2)))
    (setq pp1 pt4
          pp2 pt3
          pp3 pt2
          pp4 pt1
(setq num 1
      txt 65
(setq ww (distance pp1 pp2))
(setq hh (distance pp1 pp4))
(setq pt1 pp4 ppbas pp4
      key 1
)                                        ;行
(repeat        hnn
  (setq pt1 (polar pt1 (* pi 1.5) (/ hh hnn)))
  (setq pt2 (polar pt1 0 ww))
  (command "line" pt1 pt2 "")
  (if (> key 1)
      (setq txtins (inters ppbas
                           (polar pt1 0 (/ ww wnn))
                           pt1
                           (polar ppbas 0 (/ ww wnn))
      (command "text" "m" txtins (/ hh hnn 2) 0 (itoa num))
      (setq num (1+ num))
  (setq        ppbas pt1
        key   (1+ key)
  (setq        pt1 pp4
        ppbas pp4
        key 1
  )                                        ;列
  (repeat wnn
    (setq pt1 (polar pt1 0 (/ ww wnn)))
    (setq pt2 (polar pt1 (* pi 1.5) hh))
    (if        (> key 1)
                             pt1
                             (polar ppbas (* pi 1.5) (/ hh hnn))
        (command "text" "m" txtins (/ hh hnn 2) 0 (chr txt))
        (setq txt (1+ txt))
    (setq ppbas        pt1
          key        (1+ key)
  (prin1)
总是出现  二维 和 三维  NIL 的错误
发表于 2003-5-22 08:05:00 | 显示全部楼层
修好了,自已比較看看那裡錯!
(defun c:bg ()
  (setvar "osmode" 0)
  (setq wnn (getint "\n列数 <5>:"))
  (if (null wnn)
    (setq wnn 6)
    (setq wnn (+ 1 wnn))
  (setq hnn (getint "\n行数 <5>:"))
  (if (null hnn)
    (setq hnn 6)
    (setq hnn (+ 1 hnn))
  (setq pt4 (list (car Pt1) (cadr pt3)))
  (cond
    ((and (> ang 0) (< ang (/ pi 2)))
     (setq pp1 pt1
           pp2 pt2
           pp3 pt3
           pp4 pt4
     (setq pp1 pt2
           pp2 pt1
           pp3 pt4
           pp4 pt3
     (setq pp1 pt3
           pp2 pt4
           pp3 pt1
           pp4 pt2
     (setq pp1 pt4
           pp2 pt3
           pp3 pt2
           pp4 pt1
  (setq        num 1
        txt 65
  (setq        pt1 pp4
        ppbas pp4
        key 1
  )                                        ;行
  (repeat hnn
    (if        (> key 1)
                             pt1
        (setq num (1+ num))
    (setq ppbas        pt1
          key        (1+ key)
  (setq        pt1 pp4
        ppbas pp4
        key 1
  )                                        ;列
  (repeat wnn
    (if        (> key 1)
                             pt1
        (setq txt (1+ txt))
    (setq ppbas        pt1
          key        (1+ key)
  (prin1)
 楼主| 发表于 2003-5-22 08:38:00 | 显示全部楼层
多谢 龙龙仔 。
GMT+8, 2025-7-3 03:16 , Processed in 0.171366 second(s), 25 queries , Gzip On.
