查看: 2341|回复: 4
[求助]有没办法知道当前加载的外部文件的所有命令
发表于 2008-7-19 01:08:00 | 显示全部楼层 |阅读模式
不论是.LSP还是.ARX或者.VLX等内的命令都能全部列出来.
不能的话如何知道指定的某个文件内的命令名
发表于 2008-7-19 10:11:00 | 显示全部楼层
(atoms-family 0)
发表于 2008-7-19 20:51:00 | 显示全部楼层
试了一下,好象不行啊
全是函数名
命令: (atoms-family 0)
XTHOME vla-put-ViewToPlot vla-get-AltSuppressTrailingZeros :VLR-Editor-Reactor
acByLayer acAlignmentTopRight vla-put-FontFileMap vla-put-URLNamedLocation
acSelectionSetFence vla-put-FullScreenTrackingVector vlax-curve-getEndParam
DIAMETERSEL WRITE-LINE vla-put-EndParameter vla-MoveAbove vla-PlotToFile
vla-get-ImageFile :VLR-objectClosed C:PSTSCALE AI_DIM_CEN ENTDEL
VL-REGISTRY-DESCENDENTS acPlotOrientationPortrait vla-put-TextRotation
ASM:GET_POM VL-INIT vla-get-Center vla-put-ToleranceJustification
vla-get-ShowPlotStyles AI_RETURN C:SAVEALL SUBPTGUJIN)itleVertInsideVisibility
vla-get-LineSpacingDistance vla-get-LogFilePath < vla-get-OLEQuality
vla-get-MenuFileName LXJ:ISALINE acOff vla-get-Mask vla-put-TextFontStyle
vla-put-AllowLongSymbolNames vla-put-OleItemType AI_SHOWEDGE_ALERT XDSIZE
safearray-value vla-put-AltSuppressLeadingZeros vla-SetFitPoint
vla-get-GripSize vla-get-ToolPalettePath vla-get-Arrowhead2Block
vlax-curve-getDistAtPoint vla-put-RoundDistance vla-get-HasVpAssociation
vla-get-ArcPoint vla-put-LinetypeGeneration ACET-DICT-ENAME C:-BLOCKREPLACE
vla-GetGridColor acViewport3Below vla-get-SnapRotationAngle BNS_BLKTBL_MATCH
C:QQUIT vla-put-FitPoints vla-get-PlotWithPlotStyles vla-get-Explodable
VLR-Insert-Reactor ACET-ANGLE-EQUAL acSymAbove acSCM vla-get-PatternName
ACET-PLINE-IS-2D ACET-UI-PICKDIR acToolbarFloating vla-get-LinetypeGeneration
NUMBERSUB1 PROGN vla-GetAllProfileNames vla-AddEllipse C:RTEXTAPP
acHorizontalAlignmentMiddle acHatchStyleNormal acPrinterNeverAlert
发表于 2008-7-19 22:26:00 | 显示全部楼层
当然全是函数名。这只能提供一种方法,在加载前将函数名保存在变量中,加载后再读出函数名,去除加载前的函数名就是加载的函数名了。
 楼主| 发表于 2008-7-20 04:08:00 | 显示全部楼层
我地乖乖哩
直接看不懂 好乱那
ypeGeneration PROGN vla-GetAllProfileNames vla-AddEllipse C:RTEXTAPP
ACET:DIRECTORY / ENTLAST acLnWt211 acEnableSCM ACET-PLINES-REBUILD ACET:IDCLOSE
acKeyboardEntryExceptScripts vla-get-MaxActiveViewports - LSH
vla-put-ExtLine2StartPoint vla-get-PickGroup :VLR-dxfInComplete VL-INFP
vla-put-PlotOrigin vla-put-ToleranceSuppressLeadingZeros ACET-DTOR
C:ACETUCS-TOP + ACET-UNDO-RESTORE vla-put-ExtLine2EndPoint *
acViewport2Vertical vla-AngleFromXAxis :VLR-endInsert FITSTR2LEN
ACET-INIT-PRODKEY ACADSECURITYPARAMS_SIGN_DATA vla-get-ModelType
vla-get-ObjectName vla-AddLeader ACET:ACETAUTO vla-get-Enable SLIDE_IMAGE BPOLY
vla-put-SuppressZeroInches vla-get-TextStyle vla-get-Columns
ACET-REACTOR-EXISTS vla-put-SnapRotationAngle ACET-UNDO-BEGIN vla-get-Comment
VLR-trace-reaction MENUGROUP acHatchObject vla-GetCellStyleOverrides
ACET-SS-REMOVE-DUPS ACET-REG-PUT acArrowOpen90 acHeaderHorzBottomVisibility
vla-get-CategoryName vla-get-Saved ACET-GEOM-OBJECT-Z-AXIS ACTION_TILE
acAlignmentBottomCenter vla-put-ZScaleFactor vla-get-Check CAYVPMODE
acTableTopToBottom vla-GetBoundingBox vla-get-TextHeight
vla-AttachToolbarToFlyout <= acTrue acLnWt200 vla-GetText :VLR-beginInsert MAX
SUBSTR acExternalReference vla-get-ForceLineInside vla-SelectSubRegion C:BCOUNT
acTrace vla-get-AltTextSuffix vla-put-YVector TBLOBJNAME acFalse
vla-get-WindowLeft vlax-safearray-fill ACET-TABLE-NAME-LIST vla-ScaleEntity
ACET-ALT-VIEWPORT ACET-UCS-CMD acUnion acOCS acDimEngineering
vla-put-RenderSmoothness AI_STRTRIM ACET-UI-TABLE-NAME-CHECK-FLAGS ACET-ERROR
ACET-INSERT-ATTRIB-SET ACET-FILENAME-EXT-REMOVE SSNAMEX vla-SetBlockRotation
vla-get-XRefDatabase ACET-REG-GET acHatchLoopTypePolyline
vla-get-SingleDocumentMode :VLR-xrefSubcommandPathItem ACET-GEOM-POINT-INSIDE
AI_PUTMENUCFG vla-get-ModelSpace vla-put-Plottable acOPQHighGraphics
ACET-FULL-DWGNAME ACET-UTIL-VER acHorzTop C:DIMSIO vla-get-YVector
vla-get-ObjectSortBySelection vla-get-OleSourceApp vla-put-ExtLine1Point
VL-STRING-ELT acSelectionSetCrossingPolygon vla-AddMInsertBlock vla-GetCorner
vla-put-ShowRotation vla-GetPoint vlax-variant-type BNS_VP_ON_SCREEN
ACET-GEOM-OBJECT-END-POINTS QUIT acViewport2Horizontal
vla-put-SuppressLeadingZeros vla-put-LeaderLength acShadePlotWireframe
vla-get-SnapOn vla-get-LowerLeftCorner vlax-curve-isPlanar :VLR-Object-Reactor
:VLR-mainFrameMovedOrResized C:AI_DIM_TEXTHOME vla-put-ViewToPlot
vla-get-AltSuppressTrailingZeros :VLR-Editor-Reactor acByLayer
WRITE-LINE vla-put-EndParameter vla-MoveAbove vla-PlotToFile vla-get-ImageFile
:VLR-objectClosed C:PSTSCALE AI_DIM_CEN ENTDEL VL-REGISTRY-DESCENDENTS
acPlotOrientationPortrait vla-put-TextRotation VL-INIT vla-get-Center
vla-put-ToleranceJustification vla-get-ShowPlotStyles AI_RETURN
C:SAVEALL)ainDictionary vla-AddObject C:TEXTFIT C:AI_SPHERE C:AI_CONE
AI_COMMON_STATE vla-put-UpsideDown AI_ERROR _VER ACET-SYSVAR-SET
vla-get-PaperUnits vla-put-HatchStyle vla-GetExtensionDictionary
vlax-import-type-library vla-get-LargeButtons ACET-LSP-LOAD
ACET-SETVAR-FIXED-PROFILE acVp3in_1ft vla-put-EndPoint vlax-vbLowerCase
ACET-UCS-TO-OBJECT VL-FILENAME-BASE > >= vla-get-HasExtensionDictionary =
acTitleVertInsideVisibility vla-get-LineSpacingDistance vla-get-LogFilePath <
vla-get-OLEQuality vla-get-MenuFileName acOff vla-get-Mask
vla-put-TextFontStyle vla-put-AllowLongSymbolNames vla-put-OleItemType
AI_SHOWEDGE_ALERT XDSIZE safearray-value vla-put-AltSuppressLeadingZeros
vla-SetFitPoint vla-get-GripSize vla-get-ToolPalettePath
vla-get-Arrowhead2Block vlax-curve-getDistAtPoint vla-put-RoundDistance
vla-get-HasVpAssociation ACET-DICT-ENAME vla-put-LinetypeGeneration
C:-BLOCKREPLACE vla-GetGridColor acViewport3Below vla-get-SnapRotationAngle
BNS_BLKTBL_MATCH C:QQUIT vla-put-FitPoints vla-get-PlotWithPlotStyles
VLR-Insert-Reactor ACET-ANGLE-EQUAL acSCM vla-get-PatternName ACET-PLINE-IS-2D
GMT+8, 2025-9-21 04:16 , Processed in 0.162291 second(s), 25 queries , Gzip On.
