查看: 2452|回复: 1
[求助]设置活动图层的问题
发表于 2008-7-19 13:46:00 | 显示全部楼层 |阅读模式
在VB.NET2005中,执行以下代码设置当前图层时,如果引用了AutoCAD则没问题,如果没引用的话,最后一句会出错,谁能帮我处理一下?
dim myc as object
dim mydwg as object
dim aclay as object
   Myc = GetObject(, "AutoCAD.Application")
        If Err.Number <> 0 Then
            Myc = CreateObject("AutoCAD.application", )
            Err.Clear()
        End If
        Myc.Visible = True
        Mydwg = Myc.ActiveDocument
        For Each aclay In mydwg.layers
            If aclay.name = "table" Then
                Exit For
            End If
        Next
        mydwg.activelayer=aclay
发表于 2009-3-27 15:37:00 | 显示全部楼层
运行这个会提示:找不到成员。 (异常来自 HRESULT:0x80020003 (DISP_E_MEMBERNOTFOUND))
谁能解决??????????
GMT+8, 2025-11-26 15:18 , Processed in 0.157681 second(s), 23 queries , Gzip On.
