看看是不是你想要的 ;对象到图层 (defun c:ccc(/ a) (setq a (ssget)) (command "copy" a "" "0,0" "0,0") (command "change" a "" "p" "la" "DM" "") (command "copy" a "" "0,0" "0,0") (command "change" a "" "p" "la" "DX" "") (command "copy" a "" "0,0" "0,0") (command "change" a "" "p" "la" "UU" "") (command "copy" a "" "0,0" "0,0") (command "change" a "" "p" "la" "Uz" "") (command "copy" a "" "0,0" "0,0") (command "change" a "" "p" "la" "US" "") (prompt "\n复制对象到 DM DX UU UZ US图层:") (princ)) (DEFUN c:CYY() (setq a (ssget)) (setq b (getstring "\n 请输入层名:")) (command "chprop" a "" "la" b"") (prompt "\n移动对象到指定图层:") (princ)) (DEFUN c:CCY() (setq a (ssget)) (setq b (getstring "\n 请输入层名:")) (command "_copy" a "" "@" "@") (command "chprop" a "" "la" b"") (prompt "\n复制对象到指定图层:") (princ)) ;;;********----------------------*********** |
