查看: 1001|回复: 1
XLAX类模块在哪里下载?
发表于 2008-7-24 13:14:00 | 显示全部楼层 |阅读模式
http://www.mjtd.com/e-zine/list04.htm
有这么如下描述,问XLAX类模块在哪里下载?
要使用以下代码,你必须将XLAX类模块输入到你的工程中。如果你还没有,可以在本站下载。
Public Sub AddXdataToVertices()
 Dim obj As VLAX, ent As AcadObject
 Dim vertex As AcadObject, xType(0 To 1) As Integer, xData(0 To 1)
 ThisDrawing.Utility.GetEntity ent, pt, "Select polyline"
 If TypeOf ent Is AcadPolyline Then
  Set obj = New VLAX
  obj.EvalLispExpression "(defun getvertices (poly / tmp lst) " & _
              "(setq tmp (entget (entnext poly))) (while " & _
              "(= (cdr (assoc 0 tmp)) ""VERTEX"") (setq lst " & _
              "(cons (cdr (assoc 5 tmp)) lst) tmp (entget " & _
              "(entnext (cdr (assoc -1 tmp)))))) (reverse lst))"
  obj.EvalLispExpression _
              "(setq vertexlist (getvertices (handent """ &_
               ent.Handle & """)))"
  retVal = obj.GetLispList("vertexlist")
  obj.NullifySymbol "getvertices", "vertexlist"
  xType(0) = 1001: xData(0) = "MY_APP"
  For i = LBound(retVal) To UBound(retVal)
   xType(1) = 1000: xData(1) = retVal(i)
   Set vertex = ThisDrawing.HandleToObject(retVal(i))
   vertex.SetXData xType, xData
  Next
 End If
End Sub
发表于 2008-7-24 18:19:00 | 显示全部楼层
GMT+8, 2025-5-1 10:14 , Processed in 0.158893 second(s), 24 queries , Gzip On.
