查看: 1062|回复: 1
自动重载xref
发表于 2008-7-24 14:24:00 | 显示全部楼层 |阅读模式
经常绘图的人会把xref 设置成绝对路径
所以一气之下做了个东西.
以后方便
(Defun c:xx()
(vl-load-com)
(setq ssg (ssget "x" '((0 . "insert"))))
(setq xpath (getstring "Input xref path:"))
  (setq i 0)
  (repeat (sslength ssg)
 (setq obj (vla-item (vla-get-blocks (vla-get-activedocument (vlax-get-acad-object))) (cdr (assoc 2 (entget (ssname ssg i))))))
 (if (= (vla-get-isxref obj) :vlax-true) (vla-put-path obj (strcat xpath (vla-get-name obj) ".dwg")))
    (setq i (1+ i))
(command "_xref" "r" "*")
发表于 2016-10-19 17:09:41 | 显示全部楼层
厉害了我的哥,这个不错不错
GMT+8, 2025-10-26 04:04 , Processed in 0.166601 second(s), 25 queries , Gzip On.
