查看: 1124|回复: 0
判断图层是否存在的方法.
发表于 2008-7-26 22:48:00 | 显示全部楼层 |阅读模式
下面程序是图层字符串是否在图层数据集内存在.
采用方法是通过在数据集内循环比较.
Function abc(tt As String) As Boolean
Dim AA As AcadLayer
For Each AA In ThisDrawing.Layers
  If Trim(AA.Name) = Trim(tt) Then
    abc = True
    Exit Function
  End If
Next AA
abc = False
End Function
Sub lslsls()
  Dim gg
  gg = abc("尺寸线")
  Dim AA As AcadLayer
  If gg = False Then
    Set AA = ThisDrawing.Layers.Add("尺寸线")
  End If
  Debug.Print gg
End Sub
.Layers.Item(ii).Name可以直接调用到图层名
  For ii = 0 To ThisDrawing.ModelSpace.Count
    Debug.Print ThisDrawing.Layers.Item(ii).Name
  Next ii
GMT+8, 2025-2-22 02:12 , Processed in 0.143160 second(s), 23 queries , Gzip On.
