查看: 1283|回复: 2
为什么没有handle
发表于 2008-8-3 10:12:00 | 显示全部楼层 |阅读模式
Sub jim()
Dim m As Integer
Dim sel1 As AcadSelectionSet
Dim sel2 As AcadSelectionSet
Dim first As Variant
Set sel1 = ThisDrawing.SelectionSets.Add("TEST1_Sjsh")
sel1.SelectOnScreen
Set first = ThisDrawing.SelectionSets.Item("TEST1_Sjsh")
Dim handle1 As Variant
handle1 = first.Handle
sel1.Delete
End Sub
我对first和handle1添加了监视,怎么first里面没有handle的属性呢?难道first不是object吗?请大家指教
发表于 2008-8-3 10:41:00 | 显示全部楼层
Sub jim()
Dim m As Integer
sel1.SelectOnScreen
Set first = sel1(0)      '改这句就行了
sel1.Delete
End Sub
 楼主| 发表于 2008-8-3 18:35:00 | 显示全部楼层
谢谢,非常感谢
GMT+8, 2025-5-1 09:54 , Processed in 0.161261 second(s), 23 queries , Gzip On.
