查看: 1480|回复: 2
[讨论]GetKeyWord设置默认值
发表于 2008-8-3 22:31:00 | 显示全部楼层 |阅读模式
代码如下:
  Dim strCal_Yjs As String  '判断“已计算”层的值是否也参加计算
  Dim strlyrs As String
  With ThisDrawing.Utility
    .InitializeUserInput 1, "Yes No"
    strCal_Yjs = .GetKeyword(vbCr & "已计算层的值是否加入计算?[是(Y)/否(N)]:")
  End With
  Select Case strCal_Yjs
    Case "Yes"
      strlyrs = """填方标注""" & "," & """挖方标注""" & "," & """已计算"""
    Case "No"
      strlyrs = "填方标注" & "," & "挖方标注"
  End Select
  ThisDrawing.Utility.Prompt vbCr & strlyrs
我想实现的功能是,当提示用户输入Y或N的时候,默认值设为Y,请问怎么达到这个目的。
谢谢大家的建议!
 楼主| 发表于 2008-8-4 08:21:00 | 显示全部楼层
顶  顶
发表于 2008-8-4 12:53:00 | 显示全部楼层
        Case "No"
     Case Else
  End Select
GMT+8, 2025-5-1 10:13 , Processed in 0.177420 second(s), 24 queries , Gzip On.
