查看: 1608|回复: 1
[求助]vba数据库问题
发表于 2003-5-23 03:08:00 | 显示全部楼层 |阅读模式
您好:
我用vba连数据库,但出现一个问题:当使用如下代码试
cmd.CommandText = "INSERT INTO valveblock VALUES ('leoblock','2','success')"
程序可正常使用
但当我想用  变量传递数据时:如
dim x as string
x="leoblock"
cmd.CommandText = "INSERT INTO valveblock VALUES ('x','2','success')"
cmd.CommandText = "INSERT INTO valveblock VALUES (x,'2','success')"
此时程序报错,不只有无方法解决
请高手指点!谢谢!
发表于 2003-5-23 09:55:00 | 显示全部楼层
应该这样写
dim x as string
x="leoblock"
cmd.CommandText = "INSERT INTO valveblock VALUES(' & x & "','2','success')"
GMT+8, 2025-8-28 05:13 , Processed in 0.177307 second(s), 23 queries , Gzip On.
