查看: 1134|回复: 1
VB+类模块CLS+SelectionSets的应用
发表于 2008-8-16 22:00:00 | 显示全部楼层 |阅读模式
Dim xlsMdb As New XlsMdbTxtData
Dim CadEnt As New AcadEntity
'主程序
Private Sub Form_Load()
  Dim ojbLine As AcadLine
  Dim pp(0 To 2) As Double, ppp(0 To 2) As Double
  Dim xlSheet1 As Worksheet
  Set xlSheet1 = xlsMdb.ReturnxlSheet("Sheet1")
  Dim objText As AcadText, objTextSelectSet As AcadSelectionSet
  Dim fTypa As Variant, fData As Variant
  fType = Array("0"): fData = Array("Text")
  Set objTextSelectSet = CadEnt.ReturnAllSelectSet(fType, fData)
  Debug.Print objTextSelectSet.Count
  For ii = 0 To objTextSelectSet.Count - 1
    Set objText = objTextSelectSet.Item(ii)
    xlSheet1.Cells(ii + 1, 1) = objText.TextString
  Next ii
End Sub
'类模块
Function ReturnAllSelectSet(fTypeArray As Variant, fDataArray As Variant) As AcadSelectionSet
  Dim appAutoCAD As AutoCAD.AcadApplication
  On Error Resume Next
  Set appAutoCad = GetObject(, "AutoCAD.Application")
  If Err Then
    Err.Clear
    Set appAutoCad = CreateObject("AutoCAD.Application")
  End If
  appAutoCad.Visible = True
  Dim AcadDoc As AcadDocument
  Set AcadDoc = appAutoCad.ActiveDocument
    Dim fType, fData
    ReDim fType(0 To UBound(fTypeArray) + 2) As Integer
    ReDim fData(0 To UBound(fDataArray) + 2) As Variant
    fType(0) = -4
    For ii = 0 To UBound(fTypeArray)
      fType(ii + 1) = fTypeArray(ii)
    Next ii
    fType(UBound(fType)) = -4
    fData(0) = "<Or"
    For ii = 0 To UBound(fDataArray)
      fData(ii + 1) = fDataArray(ii)
    Next ii
    fData(UBound(fData)) = "Or>"
    '选择过滤出图形中所有的标注对象
  With AcadDoc
    .SelectionSets("mccad").Delete
    Set Sset = .SelectionSets.Add("mccad")
    '建立过滤器
    '选择过滤出图形中所有的标注对象
    Sset.Select 5, , , fType, fData
    Set ReturnAllSelectSet = Sset
  End With
End Function
 楼主| 发表于 2008-9-2 21:23:00 | 显示全部楼层
Sub LS()
  Dim rr As AcadSelectionSet
  Set rr = ReturnAllSelectSet(fType, fData)
  For ii = 0 To rr.Count - 1
    Select Case rr.Item(ii).ObjectName
      Case "AcDbText"
        Set objText = rr.Item(ii)
        With objText
          Debug.Print .TextString
        End With
    End Select
  Next ii
End Sub
  Dim appAutoCad As AutoCAD.AcadApplication
  If Err Then
    Err.Clear
  End If
    Dim fType, fData
    fType(0) = -4
    Next ii
    fData(0) = "<Or"
    Next ii
    '选择过滤出图形中所有的标注对象
  With AcadDoc
    '建立过滤器
    '选择过滤出图形中所有的标注对象
  End With
End Function
GMT+8, 2025-5-1 08:02 , Processed in 0.210997 second(s), 23 queries , Gzip On.
