查看: 1627|回复: 4
[求助]自动打印
发表于 2008-8-17 00:20:00 | 显示全部楼层 |阅读模式
以上是偶整理的自动打印程序,有谁能帮偶修改下,改成可以使用网络打印机自动打印就好了
发表于 2008-8-17 01:25:00 | 显示全部楼层
;圖塊批量打印程序 給你參考一下看看我用的
;提示下這裡沒修改坐標 當打印時不再世界坐標系下要經過坐標轉換
(defun c:plp (/ a4l aa ll n p1 p2 plot_ss ww zhixing)
  ;(setvar "osmode" 16384)
  ;(setvar "cmdecho" 0)
  (initget 1 "A4 A3")
  (setq aa (strcase (getkword "\n指定要打印的紙型A4/A3:")))
  (cond ((= aa "A4") (setq zhixing "A4(210 x 297mm)"))
 ((= aa "A3") (setq zhixing "A3(297 x 420mm)"))
  (prompt "\n選取需打印的對象<塊>:")
  (setq plot_ss (ssget (list (cons 2 "bom_frame,enregister_Q,A3,A4,set up type"))))
;指定要打印的塊
  (setq n 0)
  (repeat (sslength plot_ss)
    (setq p1 (car (setq a4l (acet-ent-geomextents (ssname plot_ss n)))))
    (setq p2 (cadr a4l))
    (setq ll (abs (- (car p2) (car p1))))
    (setq ww (abs (- (cadr p2) (cadr p1))))
    (if (> ll ww)
      (command "-plot"  "y"   "MODEL"
        "Previous PLOT" "\\\\Prnsrv\\\*****"
        zhixing  "Millimeters"  "Landscape"
        "n"  "w"   p1
        p2  "f"   "c"
        "y"  "monochrome.ctb" "y"
        "w"  "n"   "n"
        "y"
        zhixing  "Millimeters"  "Portrait"
        "n"  "w"   p1
        p2  "f"   "c"
        "w"  "n"   "n"
        "y"
    )     ;if
    (setq n (1+ n))
  )     ;repeat
发表于 2008-8-29 08:27:00 | 显示全部楼层
试试
 楼主| 发表于 2008-9-7 13:37:00 | 显示全部楼层
谢谢二楼指点,下下来试试看
GMT+8, 2025-10-25 03:45 , Processed in 0.190151 second(s), 26 queries , Gzip On.
