- 积分
- 5989
- 明经币
- 个
- 注册时间
- 2006-7-8
- 在线时间
- 小时
- 威望
- 金钱
- 个
- 贡献
- 激情
楼主 |
发表于 2008-9-8 23:08:00
显示全部楼层
 - Sub ls()
- nn = ThisDrawing.ModelSpace.Count - 1
- Dim objText As AcadText, objLine As AcadLine
- Dim Xls As New XlsMdbTxtData
- Dim xx As Worksheet
- Set xx = Xls.ReturnxlSheet("Sheet1")
- xx.Range("A:z").ClearContents
- For ii = 0 To nn
- Select Case ThisDrawing.ModelSpace.Item(ii).ObjectName
- Case "AcDbText"
- Set objText = ThisDrawing.ModelSpace.Item(ii)
- aa = Split(objText.TextString, ",")
- ' For jj = 0 To UBound(aa)
- 'Set objLine = ThisDrawing.HandleToObject(aa(1))
- With objLine
- ' Debug.Print .Delta(0), .Delta(1)
- End With
- ' Next jj
- Case "AcDbLine"
- Set objLine = ThisDrawing.ModelSpace.Item(ii)
- With objLine
- 'Debug.Print Format(.Delta(0), "0.00"), Format(.Delta(1), "0.00"), .Angle
- xx.Cells(ii + 1, 1) = Format(.Delta(0), "0.0000")
- xx.Cells(ii + 1, 2) = Format(.Delta(1), "0.0000")
- xx.Cells(ii + 1, 3) = Format(.Angle, "0.0000")
- gg = "Hexagon(" & ii
- gg = gg & ")=array("
- If Abs(Round(.Delta(0), 4)) = 5.7735 Then
- gg = gg & " S/tan(" & Format(.Angle, "0.0000") & ")"
- End If
- gg = gg & ","
- If Abs(Round(.Delta(1), 2)) = 10 Then
- gg = gg & .Delta(1) / Abs(.Delta(1)) & "* S"
- End If
- gg = gg & ")"
- Debug.Print gg
- Set objText = ThisDrawing.ModelSpace.AddText(tt, .StartPoint, 0.5)
- End With
- End Select
- Next ii
- End Sub
- Sub ms()
- S = 20
- Dim Hexagon(6) As Variant
- Dim pp(0 To 2) As Double, ppp(0 To 2) As Double
- Dim objLine As AcadLine
- Hexagon(0) = Array(-S / Tan(4.1888), -1 * S)
- Hexagon(1) = Array(-S / Tan(5.236), -1 * S)
- Hexagon(2) = Array(-2 * S / Tan(5.236), 0)
- Hexagon(3) = Array(1 * S / Tan(1.0472), 1 * S)
- Hexagon(4) = Array(1 * S / Tan(2.0944), 1 * S)
- Hexagon(5) = Array(2 * S / Tan(2.0944), 0)
- Hexagon(6) = Array(-S / Tan(4.1888), -1 * S)
- For ii = 0 To 5 'Step 2
- pp(0) = Hexagon(ii)(0): pp(1) = Hexagon(ii)(1)
- ppp(0) = Hexagon(ii + 1)(0): ppp(1) = Hexagon(ii + 1)(1)
- Set objLine = ThisDrawing.ModelSpace.AddLine(pp, ppp)
- Next ii
- End Sub
