查看: 823|回复: 3
[求助]帮忙看看这个是什么毛病!!
发表于 2008-9-6 15:48:00 | 显示全部楼层 |阅读模式
  (defun c:yy()
  (setvar "cmdecho" 0)
  (princ "请选择需要打散的文字:")
  (setq text (car(entsel)))
  (setq te (entget text))
  (setq text1 (cdr (assoc 1 te)))
  (setq high  (cdr (assoc 40 te)))
  (setq lyr   (cdr (assoc 8 te)))
  (setq zx   (cdr (assoc 7 te)))
  (command "-layer" "s" lyr "")
  (command "-color" "bylayer")
  (if (/= "" (cdr(assoc 4  (tblsearch "style" zx ))))
  (setq zt (strcat (cdr(assoc 3  (tblsearch "style" zx ))) "," (cdr(assoc 4  (tblsearch "style" zx )))))
  (setq zt (cdr(assoc 3 (tblsearch "style" zx ))))
  );end if
  (command "-style" zx zt "0" "1" "" "" "" "")
  (setq len (strlen text1))
  (setq n 1)
  (setq j 1)
      (while(<= n len)
      (if(> (ascii(substr text1 n 1)) 127)(progn
           (setq stm (substr text1 n 2))
           (princ "\n请指定第") (princ j) (princ "个点的位置:")
           (setq xy (getpoint))
           (command "text" "j" "ml" (list (- (car xy) (/ high 2))  (cadr xy)  ) high "0" stm)
           (setq j (+ j 1))
           (setq n (+ n 2)))(progn
           (setq stm (substr text1 n 1))
           (setq j (+ j 1))
           (setq n (+ n 1)))
      );end if
      );end while
  (setvar "cmdecho" 1)
);end defun
请选择需要打散的文字:
选择对象: 未知命令“YY”。按 F1 查看帮助。
请指定第1个点的位置:
请指定第2个点的位置:
请指定第3个点的位置:
能顺利执行,选择对象之后会出现错误“未知命令“YY”。按 F1 查看帮助”
发表于 2008-9-6 16:00:00 | 显示全部楼层
删除最后一个回车
 楼主| 发表于 2008-9-6 16:19:00 | 显示全部楼层
也不行,shx文件和TTF文件情况不一样!!SHX文件有个是否垂直!!
发表于 2008-9-6 16:50:00 | 显示全部楼层
改成
(command "-style" zx zt "0" "1")
(while (/= 0 (getvar "cmdactive")) (command ""))
GMT+8, 2025-9-21 09:08 , Processed in 0.174699 second(s), 25 queries , Gzip On.
