查看: 2058|回复: 5
ZZXXQQ大哥,再帮一下撒,搞了一天都不知那错啦
发表于 2008-9-6 16:19:00 | 显示全部楼层 |阅读模式
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-9-6 16:49:00 | 显示全部楼层
(defun loaddir (d extname)
  (setq lst nil)
  (setq extname (strcase extname))
  (mapcar '(lambda (x)
             (if (= (strcase (vl-filename-extension x)) extname)
               (setq lst (cons (strcat d x) lst))
             (if (vl-file-directory-p (strcat d x))
               (loaddir (strcat d x "\\") extname)
          (setq jj (vl-directory-files d))
  lst
 楼主| 发表于 2008-9-6 17:05:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2008-9-6 17:31:00 | 显示全部楼层
(defun lt:path-addBackSlash (path)
  (setq path (vl-string-translate "/" "\\" path))
  (if (wcmatch path "*\\") path (strcat path "\\"))
;;____________________________________________________________________________________________________
;; ▓ (lt:load-allLispAtDir dir)
;; [功能] 加载指定目录中所有 LISP 程序程序
;; [参数] dir---目录
;; [测试] (lt:load-allLispAtDir "c:\\lisp")
(defun lt:load-allLispAtDir (dir)
  (setq dir (lt:path-addBackSlash dir))
  (foreach x '("*.lsp" "*.fas" "*.vlx")
             (foreach y (vl-directory-files dir x 1) (load (strcat dir y)))
发表于 2013-8-31 00:27:58 | 显示全部楼层
caoyin 发表于 2008-9-6 17:31
(defun lt:path-addBackSlash (path)  (setq path (vl-string-translate "/" "\\" path))  (if ( ...
本人新手,试了您给的,一直调试不成功,请赐教
发表于 2022-12-10 08:56:18 | 显示全部楼层
高手在民间
GMT+8, 2025-8-23 04:18 , Processed in 0.160451 second(s), 25 queries , Gzip On.
